2150 leaking oil out the top of the steering column
   / 2150 leaking oil out the top of the steering column #1
double hunter
Gold Member
Ford 1715
MY neighbor has a JD2150,,it has started leaking oil out the top of the steering column,,I have been told there is a seal at the top of column, any help appreciated
   / 2150 leaking oil out the top of the steering column #2
There is a seal kit, JD part # AT26188 listed for that column.
And you can go to jdparts under model 2150 to check out the parts in that column..
John Deere - Parts Catalog
   / 2150 leaking oil out the top of the steering column #3
Yes there's a seal below steering wheel but replacing that seal may or may not stop leak.Seal part number is T22260
   / 2150 leaking oil out the top of the steering column #4
Every seal in it will need to be replaced if he has a chance of stopping the leak. I tried replacing just the six o-rings in the top side and it lasted all of 1 day. Had to get another kit and completely disassemble the thing. There's a video on YouTube of a guy removing one and rebuilding it. He needs to watch it. It's not an easy job.
   / 2150 leaking oil out the top of the steering column #6
One doesn't have to remove valve housing from tractor similar to U-tube video to install seals. Remove steering wheel then remove large nut then set steering wheel back on shaft,turn steering wheel CCW& shaft with valves will come out of housing. Then the 6 large o-rings can be replaced being careful to get o-rings in proper locations. If valves & other components are removed from shaft be sure & document proper location of shims & valve bodies.
   / 2150 leaking oil out the top of the steering column #7
Thanks for the useful post. I hope I never have to do this repair
   / 2150 leaking oil out the top of the steering column #8
DISCLAIMER: the six o-rings can be replaced as described above BUT replacing them isn't an easy task!!
2022 Brush Wolf 7800-HF Skid Steer Brush Cutter (A55315)
2022 Brush Wolf...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A55745)
2010 MAXEY WELDING...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
Deere 335P (A53317)
Deere 335P (A53317)
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
2004 MANAC 48FT CURTAIN SIDE SPREAD AXLE TRAILER (A57880)
2004 MANAC 48FT...
