2150 leaking oil out the top of the steering column
   / 2150 leaking oil out the top of the steering column #1
double hunter
Gold Member
Ford 1715
MY neighbor has a JD2150,,it has started leaking oil out the top of the steering column,,I have been told there is a seal at the top of column, any help appreciated
   / 2150 leaking oil out the top of the steering column #2
There is a seal kit, JD part # AT26188 listed for that column.
And you can go to jdparts under model 2150 to check out the parts in that column..
John Deere - Parts Catalog
   / 2150 leaking oil out the top of the steering column #3
Yes there's a seal below steering wheel but replacing that seal may or may not stop leak.Seal part number is T22260
   / 2150 leaking oil out the top of the steering column #4
Every seal in it will need to be replaced if he has a chance of stopping the leak. I tried replacing just the six o-rings in the top side and it lasted all of 1 day. Had to get another kit and completely disassemble the thing. There's a video on YouTube of a guy removing one and rebuilding it. He needs to watch it. It's not an easy job.
   / 2150 leaking oil out the top of the steering column #6
One doesn't have to remove valve housing from tractor similar to U-tube video to install seals. Remove steering wheel then remove large nut then set steering wheel back on shaft,turn steering wheel CCW& shaft with valves will come out of housing. Then the 6 large o-rings can be replaced being careful to get o-rings in proper locations. If valves & other components are removed from shaft be sure & document proper location of shims & valve bodies.
   / 2150 leaking oil out the top of the steering column #7
Thanks for the useful post. I hope I never have to do this repair
   / 2150 leaking oil out the top of the steering column #8
DISCLAIMER: the six o-rings can be replaced as described above BUT replacing them isn't an easy task!!
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
2005 Peterbilt 387 with Wet Kit (A56435)
2005 Peterbilt 387...
S/N: 5D121002416 (A55787)
S/N: 5D121002416...
2023 Chevrolet Tahoe (A54815)
2023 Chevrolet...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
2025 BrushFox HD-78STD 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
