How can I get rid of that pesky "Sign up now" popup?
   / How can I get rid of that pesky "Sign up now" popup? #1
ericoberg1
Member
Simi Valley, CA
Ford 1710
Came to the site to read up. Created a login. Occasionally just check in now and then to see replies.
I get that dammed "Sign up now" popup every 3-5 minutes. Very annoying.
Is the only way to get rid of the pop up by either signing in, OR how about going over to Discussion Forums - Yesterday's Tractors
   / How can I get rid of that pesky "Sign up now" popup? #2
Check the box "remember me" when you log in.
   / How can I get rid of that pesky "Sign up now" popup? #3
Just recently I started to get it again. I've learned I can make it go away by clicking on any of the space around it but it's annoying because the popup is totally superfluous.
   / How can I get rid of that pesky "Sign up now" popup? #4
AGREED!
   / How can I get rid of that pesky "Sign up now" popup? #6
Log out, clear browser history. You can browse your individual cookies and delete the ones from tractorbynet.com. Then when you log in click "remember me" ...
   / How can I get rid of that pesky "Sign up now" popup? #7
That doesn't explain why the popup started up again for me after several months of not doing it. I clear everything when I shut down my browser.
   / How can I get rid of that pesky "Sign up now" popup? #8
Try Logging In then never Log Out. Next time you access TBN https://www.tractorbynet.com/forums/index.php you will be automatically Logged In. The popup will not appear. I'm using a PC with Windows 10 & Firefox. Your mileage may vary if using another method.
   / How can I get rid of that pesky "Sign up now" popup? #9
So just use the popup to login... right? That's what I do. Maybe we'll change the format to position it on the bottom of the page instead of middle.
   / How can I get rid of that pesky "Sign up now" popup? #10
I don’t log out and have not encountered a problem until just a day or so ago. Come on and needed to sign in. Got caught in some kind of loop where I couldn’t log in. Changed PW and reset. On a lap top it seems to be working fine now but every time I come to TBN on an iPad I’m logged out and have to sign back on. Checking “Remember Me” doesn’t work. Finally after several attempts and no “Remember Me” check I can get signed on.
So what’s up with all the trouble staying signed on?
CFG Industry H15R Mini Excavator (A57149)
CFG Industry H15R...
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
2006 Mac 35ft Tri-Axle Dump Trailer (A56858)
2006 Mac 35ft...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
20' Sea Container (A55272)
20' Sea Container...
500BBL WHEELED...
