30x50x16 pole barn construction
/ 30x50x16 pole barn construction #62
Day 5. That platform truck is super. Should finish up the front tomorrow. View attachment 565765
Look at that. Our crews hired the same truck!
/ 30x50x16 pole barn construction #64
Pole barn is named for the construction method of using poles, it can be open or sided. It's proper name is post frame construction. Also see NFBA, National Frame Building Association.
/ 30x50x16 pole barn construction #65
Fairly common now days. They are the same shape as the roof metal. Does make a big difference.
Just wondering if you considered putting them across the side at the top, just under the eave? Do you get much hail in your area?
Very NICE Building!
/ 30x50x16 pole barn construction #67
All this debate about truss design ... I think everyone needs to take a look at the pictures again.
It appears to me the only 2x4's in the trusses are the web. The bottom cord looks like 2x6 and the top cord looks like 2x8.
/ 30x50x16 pole barn construction #68
Nobody is talking about the trusses. They look perfect. The purlins are the boards that span the distance between the trusses. To some of us who build and work on houses for a living, they are smaller for such a long span, then we would use. While they are probably fine, it is just a little surprising to see them up there.
/ 30x50x16 pole barn construction #69
Ahhhh, my mistake. I apologize.
/ 30x50x16 pole barn construction #71
Call me crazy
I consider Eddie Walker an excellent builder and would rely heavy on his opinion.
Now me on the other hand, not so much. :)
/ 30x50x16 pole barn construction #72
Day 5. The roof is on ! There is a wire mesh screen under the ridge vent to keep birds from nesting. The skylights are a nice add. Our 2 dogs keeping a eye on things ! That platform truck is super. Should finish up the front tomorrow. View attachment 565764View attachment 565765View attachment 565766View attachment 565767View attachment 565768View attachment 565769View attachment 565770
Excellent pics!!! I've never saw a lift truck before. That's very cool.
/ 30x50x16 pole barn construction #73
And in one pic it looks like they are spliced between raftr s rather than on them? Maybe used 12ft 2x4s?
/ 30x50x16 pole barn construction #74
Very NICE Building!
That is what we did on the pole barn that we put up a few years back. A 2' band under the eaves. The next one will also get one of the gable ends filled in with translucent panels as well. That way we can get more of the evening sun in.
Aaron Z
/ 30x50x16 pole barn construction #75
Aaron Z
Best way to light up a building with sunlight is from the sides.
Yes...they are spliced with metal connectors in 2 places. They are 12' ft 2x4s. The splice is not in the middle of a truss, 2' from truss.
Very NICE Building!
Thanks ! I considered under the eaves, but with the overhang it would block some sun light. Not much hail here in the mtns.
2x6 bottom chord with a 2x8 top chord. There is extra 2x4 supports in the web than a normal truss. The heel is 15"
I have to tell myself....this is a pole barn not a house ! I have stick built many buildings...never use anything less than a 2x8 for rafters if it is over a 12 ft span. After looking at the quote, all the metal siding and roofing is .019 gauge steel. It really is a strong metal, where as most builders use .026 or .029.
/ 30x50x16 pole barn construction #80
The one we put up has panels on the North and South sides under the eaves. The next one will have panels on the North and South sides under the eaves as well as panels on the West end in the gable.
Aaron Z
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
2016 Freightliner 108SD (A64194)
2016 Freightliner...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
Wolverine Quick Attach Trencher (A66408)
Wolverine Quick...
Butler MFG Water Tanker (A63689)
Butler MFG Water...
Case 950 8 Row Air Planter (A63118)
Case 950 8 Row Air...
