Allis C model, positive or negative ground?
/ Allis C model, positive or negative ground? #1
09112
N.E. Oklahoma
yanmar 3810, 48 Allis B
I have what I believe to be a 1949 Allis C engine that I put onto a B frame. It has an alternator and I'm not sure if it is positive or negative ground. Anyone out there have any views on this? What would the ramifications be if I reverse the set up and how will I know if it is correct? Really a rookie at this stuff as you might know. Electrics give me nightmares.
/ Allis C model, positive or negative ground? #2
Positive ground way back when, but who knows now. The tractor or the alternator don't really care which one it is.
Thanks for the input guys.
/ Allis C model, positive or negative ground? #7
If running alternator, it's probably going to be negative ground..... Starter and alternator care most of the other electrics don't....
Dale
/ Allis C model, positive or negative ground? #8
Dale
Starters are not polarity sensitive. To a large degree they are insensitive to higher voltage than they are wound for. Don’t fool the guy into buying a starter he doesn’t need by posting inaccuracies.
/ Allis C model, positive or negative ground? #9
Was not trying to fool anybody... Only trying to make OP aware there "may" be problem with starter, not that there actual would be....
Dale
/ Allis C model, positive or negative ground? #12
Won't the starter run backwards with the polarity reversed? That could give a clue.
/ Allis C model, positive or negative ground? #14
This one won't, but for clarity/future reference, if it's a permanent magnet starter motor as on a lot of smaller engines, they will. But of course 99.99% (I guess) of things that run with a starter with permanent magnets, are all negative ground.
