Allis C model, positive or negative ground?
   / Allis C model, positive or negative ground? #1
09112
N.E. Oklahoma
yanmar 3810, 48 Allis B
I have what I believe to be a 1949 Allis C engine that I put onto a B frame. It has an alternator and I'm not sure if it is positive or negative ground. Anyone out there have any views on this? What would the ramifications be if I reverse the set up and how will I know if it is correct? Really a rookie at this stuff as you might know. Electrics give me nightmares.
   / Allis C model, positive or negative ground? #2
Positive ground way back when, but who knows now. The tractor or the alternator don't really care which one it is.
   / Allis C model, positive or negative ground? #4
TractorData.com says that the 'C' is a positive ground.
   / Allis C model, positive or negative ground? #5
Little doubt it was, 70 years ago or so. But it didn’t have that pesky alternator then. There’s about a 95% chance the alternator is negative ground.
Thanks for the input guys.
   / Allis C model, positive or negative ground? #7
If running alternator, it's probably going to be negative ground..... Starter and alternator care most of the other electrics don't....
Dale
   / Allis C model, positive or negative ground? #8
Dale
Starters are not polarity sensitive. To a large degree they are insensitive to higher voltage than they are wound for. Don’t fool the guy into buying a starter he doesn’t need by posting inaccuracies.
   / Allis C model, positive or negative ground? #9
Was not trying to fool anybody... Only trying to make OP aware there "may" be problem with starter, not that there actual would be....
Dale
UNUSED FUTURE FT15 EXCAVATOR (A57192)
UNUSED FUTURE FT15...
2006 KOMATSU PC50MR-2 EXCAVATOR (A52707)
2006 KOMATSU...
19015 (A55788)
19015 (A55788)
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A55745)
2015 VANTAGE...
2003 JOHN DEERE 110 BACKHOE (A52707)
2003 JOHN DEERE...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
