/ Share Pics of People Hauling or Towing Something Wrong #8,341
/ Share Pics of People Hauling or Towing Something Wrong #8,343
You do? And you say you are from Tennessee?
I’ve seen some crazy stuff and I’ve done some crazy stuff but I’ve never seen anyone drag a shed down the road. Dragging a non running vehicle on a chain is pretty common.
/ Share Pics of People Hauling or Towing Something Wrong #8,344
Drug an 8 x 12 gambrel roof yard shed by a chaing 3/4 ~ 1mile down a pretty busy (had industrial parks at each end) city street behind my 9N Ford.
The trick was swinging it wide to square it up to hop the curb at its final destination.
Had no idea who or what, other than the shed was behind me the entire trip.
/ Share Pics of People Hauling or Towing Something Wrong #8,345
Highway yesterday. No straps. Wood held down by water bottles and cooler. Nothing on sheet metal pieces on right side. Image from my dash cam.
/ Share Pics of People Hauling or Towing Something Wrong #8,346
I致e seen some crazy stuff and I致e done some crazy stuff but I致e never seen anyone drag a shed down the road. Dragging a non running vehicle on a chain is pretty common.
A couple of friends dragged a pickup 15 miles to the garage after the fuel pump quit. (Not good for the AT) The mechanics lifted the bed and put in the new pump but the engine still wouldn't start.
The truck was simply out of gas.
/ Share Pics of People Hauling or Towing Something Wrong #8,347
I used to drag an old 10 x 12 3-sided shed out my driveway and to the church across the street every year for the nativity scene. I put 4 x 4s underneath and then took them out when I got to the destination so nobody would trip on them. It was about 1/2 mile pull one way. Then one year this idiot decides to pull it home for me with his truck and hooks onto the enclosed end and drug it home. That was then of that shed.
/ Share Pics of People Hauling or Towing Something Wrong #8,348
Ahaha. Reminds me of my brother getting annoyed with that stupid new electric grease gun... he forgot to pull the metal end out of the new tube.
/ Share Pics of People Hauling or Towing Something Wrong #8,349
ouch! Just like putting a saw chain on backwards, that's the kind of mistake that you only make once!
/ Share Pics of People Hauling or Towing Something Wrong #8,353
Isn't it that the third time is the charm?:D
By the third try, I have completely forgotten about the first two but something seems strangely familiar...
/ Share Pics of People Hauling or Towing Something Wrong #8,355
Then why did they put in a new fuel pump rather than check the fuel? :whistleblower:
/ Share Pics of People Hauling or Towing Something Wrong #8,357
Not a question for me to answer. When Jeff told you to change the fuel pump, you changed the fuel pump.
/ Share Pics of People Hauling or Towing Something Wrong #8,358
As a mechanic if you say: my truck wont run- I would figure out why and provide an estimate to repair. If you say: I want my fuel pump changed- I would provide an estimate.
/ Share Pics of People Hauling or Towing Something Wrong #8,359
If you have been watching the news, we have a huge fire going north of us in Redding, CA. The Carr fire, so named as it started near the Carr Powerhouse next to Whiskeytown Lake. Apparently started by a tire that failed on a travel trailer, allowing the rim to contact the pavement and spark. Over 110,000 acres, 6 lives lost so far, over 1000 homes destroyed, 38,000 evacuated at it's peak. It is now 35% contained and it looks like they are getting a handle on it.
Most of us if we have hauled a trailer much have had a flat or a blowout. It happens. They showed a picture of the travel trailer and it was a modern trailer that looked just fine. Not an old beater with worn out tires. It happened during a week of 110* plus temps and things just blew up.
This thread is about towing or hauling something wrong, but I'm not sure if the guy pulling the trailer really did anything wrong. Tires fail, you pull over and change them. That is normal enough. I'm sure they will look at the age of the tires, last time pressures were checked and so forth. It is a good reminder, especially if you live in the fire prone west, to pay attention to tire pressures and conditions. Having said that, he might have ran over a nail left in the road a mile prior...through no fault of his own. Probably best not to try to slice and dice liabilities and "what ifs", but it is interesting how such a devastating fire could be started by just towing a trailer down the road.
If you believe in prayer, as I do, then please keep the folks devastated by this fire in your prayers.
/ Share Pics of People Hauling or Towing Something Wrong #8,360
Dave, see this thread - https://www.tractorbynet.com/forums/mahindra-owning-operating/399472-gee-i-hope-dave-ok.html
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
2016 Case Magnum 310 (A60462)
2016 Case Magnum...
POLY TANK ON BRACKETS (A60429)
POLY TANK ON...
2019 CATERPILLAR 259D SKID STEER (A60429)
2019 CATERPILLAR...
2017 Toro Workman HDX-D Diesel Utility Cart (A59228)
2017 Toro Workman...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
