Quick Hitches Skid steer attachments disconnecting
/ Skid steer attachments disconnecting #21
Well yea, but in the above picture there is about a 1/2" of thread that you could use to extend the pin. If the pins are worn that much, why not just replace them?
In my case it was a nearly new tractor & new forks. The bucket fit properly. It was just the fork frame that was really loose. Nothing any where was worn. This is just my experience & might not be relevant for the other uses being discussed.
/ Skid steer attachments disconnecting #22
I'd assume that adjustment isn't the issue. The pins are spring loaded & the levers go over center. That means the springs are keeping constant pressure on the pins. Combine that with the wedges on the top & angle on the pins keep the SSQA tightening as it vibrates or wiggles.
My first set of pallet forks from Titan was similarly out of spec. The pins only barely engaged the holes on the forks. They refunded some of the price, in theory to have a local welder fix things. I just welded some bar stock to the bottom of the holes so the angle on the pins would have something to grab on & tighten up the SSQA.
Upward force resulting from the angle on the pins can easily overcome the spring force. The overcenter mechanism is designed to provide a positive stop to prevent the pins rising out of the slots.
When the pins on my 7520 are well greased they regularly rise to the stop during hard backdragging.​
/ Skid steer attachments disconnecting #23
Kioti had an issue with the SSQA back when I first bought my NX. 3rd-party attachments weren't staying put (from what I hear- I did not/have not had any issues). Suspect that their notion of spec was slightly off. Not sure what their "fix" was. Anyway, the point of my reply, it's possible that the tractor manufacturer is either out of spec or is at the edges of spec.
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
2019 CATERPILLAR 326FL EXCAVATOR (A62129)
2019 CATERPILLAR...
2018 INTERNATIONAL LT DAY CAB TRUCK TRACTOR (A59911)
2018 INTERNATIONAL...
2023 Boxer 700HDX Compact Skid Steer (A63109)
2023 Boxer 700HDX...
159119 (A60430)
159119 (A60430)
