Anyone build or make a trailer dolly?
   / Anyone build or make a trailer dolly? #21
Hard to push a 10 trailer with a 12 vehicle through a 12 wide L... Barn has a few of those. Best I can do is get close and push by hand.
Can you get close and use a winch?
Where there is a will, there is a way. That said, think I might have stripped out my lite duty warn winch doing a bit too much of that. It was never meant to winch my 50hp Ford tractor onto a lowboy.
That said, I need to play musical trailers soon and I might just end up using a comealong before it is over.
Still fence sitting on the BCS. Waiting to see how much overbudget I go on fencework before I start ordering a tractor
   / Anyone build or make a trailer dolly? #23
Hmmm, interesting thread. I got a older Mainline Mountaineer II REV1500 a few weeks back, it has turning brakes and seems fairly beefy. If I can get it to stop leaking (the input shaft and PTO shaft on the transmission leak) and run happily, I think I will set it up as a trailer mover with a heavy swivel wheel in the front and a 2" ball and a pin hitch over them so I can use it to push the hay equipment around in the barn when I am nesting it in there.
attachment.php
Aaron Z
   / Anyone build or make a trailer dolly? #24
564697d1532913433-anyone-build-make-trailer-dolly-mainlinetiller-png
Aaron Z
A heavily weighted wheel attachment would be key to balance the engine when there is no trailer on the hitch. Good idea!
Barn floor is not as level as I hoped. Spent about an hour with had and come-a-long today moving a small trailer. Almost got it were I wanted it when it jumped over my makeshift wheel chokes and rolled back where I started. Will try again when it is not raining and the trailer is not loaded.
   / Anyone build or make a trailer dolly? #26
Can you adapt this style trailer mover to the BCS?
1996 CATERPILLAR 416B BACKHOE (A51242)
1996 CATERPILLAR...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
John Deere 4520 Tractor (A50514)
John Deere 4520...
10' Feed Bunk (A50515)
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2024 Case International 45C Tractor (RIDE AND DRIVE) (LIKE NEW) (A50774)
2024 Case...
