Too much tractor?
/ Too much tractor? #1
anewuser
Northwest Louisiana
Kubota L4400HST
It's been nearly a year since I first posted about looking for my first tractor. I'm ready now to buy a 35-45HP tractor for my 7 acre place. Mostly flat, mostly pasture (barn and 2 horses), with some wooded areas surrounding the pasture.
I've been looking at used Kubotas. My neighbor has a 25hp, and less acreage. I've priced new - and although the interest rate and discounts are attractive - the 20% down is a non-starter. The only other local dealer is JD. As I've read here, I'm trying to figure out what implements and sizes I need, and finding a tractor to meet those needs, rather than the other way around. My primary need is cutting grass, but want a hefty FEL for moving downed trees and other carrying duties. The cutter should be no smaller than 5 or 6 feet, but not too big, so I can get between some of the trees. I'd also like to have a post-hole digger and a landscape rake. I've focused mainly on the "L" series. I think the "B" models are a little too lightweight, and an L would be easier to sell if I ever need to. I'd love a Grand L, but probably don't have the budget.
My local 'bota dealer sells all his trades to some guy (I haven't been able to find out what he does with them). I keep track of Craigslist and Facebook sellers, but those are very iffy. So I'm comparing tractors at distant seller locations. I'm going to have to drive at least 2 hours to look, but most places list on TractorHouse or MachineryPete, so I have an idea what they have on the lot. In the meantime, a local western store and trailer dealer has been buying and reselling tractors, mostly from individuals. I don't think he goes to auctions, but I could be wrong. I know the family, they've been local farmers for generations - and know tractors - so I told him I was ready to buy. He just bought a MX4700 with a 7 foot cutter from an individual and I'm going to look at it today.
All this to ask: is 47HP too much? Is an MX model too big? I know I should probably be the one to say if it's too big or ok, but I'd like some other perspectives. The L's I've been looking at are 3400, 3800, 3830, 3901, and 4400. I think the 3400 PTO (~29hp) is about the minimum I want to go with for a 5 to 6 foot rotary cutter. I want an HST, so I can teach my wife to use it, R4s because our ground is sandy and soft, and preferably a SSQA bucket. The 4700 is an HST with R4s, but a pin-on bucket. The 3830 with a 723 FEL would be great, but is a gear drive. The 3901 is what I'm primarily comparing to the 4700, although the 4400 is very attractive (though it has R1s). The 3901 doesn't really compare with the 4700, hence my question - is the MX too much tractor for my needs? Besides frame/tires, what other differences are there between the L and MX?
And, last question: since I don't think I can find the ideal machine, with my budget, what's best to compromise on - HP, FEL capacity, transmission, tires, SSQA?
One other consideration: weight. I've read enough on this forum to know that weight can be a big advantage. But I don't currently have a trailer big enough to haul a tractor, and my half-ton pickup is rated with a 10,000 lb towing capacity. Is a 7k or 10k trailer with a 3800 pound (dry) tractor and implements going to be too much to pull?
Thanks for your opinions.
Laner
/ Too much tractor? #2
About a 6' cutter. If a medium duty is considered ( due to having a wooded/woody area) then find out if teh FEL can handle the counter weight act.
A medium cutter (6') can weigh from 680lb to 1200 lbs).
When I got the CK4010HST the largest medium duty cutter dealer said I could run was a 5' medium duty. Anything larger would make the front end light.
So consider type of cutters sold in your area and what a 6 footer would weigh and then ask your dealers if the front end would get light using one.
A light versus medium duty. That should help with the size of tractor as it seems it will be the largest use of a PTO horse power.
Once that is determined then all other attachments should be none issue.
Hope this helps a tad.
/ Too much tractor? #3
I own an MX, also have a 22 pto hp ford which currently has a five ft woods rotary mounted. I have completed many tasks w/ BOTH tractors.
It is absolutely amazing what a 2000 lb tractor can accomplish. A fl member believes everyone needs a 4000 lb tractor. I disagree.
Other members will offer opinions. Condition of the tractor, drivetrain and features along w/ operating hrs, AND COST are the important variables. I would opt for a better deal for lesser hp/wt. Than higher hp but less favorable condition. Knowing tractor history and use is always an advantage. Be aware that some tractor sales are actually stolen equipment. Research serial # before payment.
EDIT
Jeffy, my MX, ROPS folded is under 7 ft. And an 8 ft duel spindle rotary consumes less hp than 7 ft single spindle.
/ Too much tractor? #4
<snip>
All this to ask: is 47HP too much? Is an MX model too big? <snip>
Not if your wallet can afford it.
Laner
How would you compromise on:
HP? Get smaller tractor?
FEL capacity? see above
Transmission? HST vs gear?
Tires? Turf vs R4?
SSQA - can always be added afterwards.
With a 10K tow rating on your truck a trailer rated for 10K (figure 2K for the trailer, with 4K tractor and 2K of implements) should be fine. Don't go 7K trailer.
As far as tractor sizing it seems you only have to worry about lifting "downed trees". When all I had was a B7610 I just chopped them up smaller. With my M4700 I can lift a ton. It seems like if you don't need to lift long logs in one piece (like I do for my sawmill) the 25HP Kubota might serve you fine. I would not go geared unless there was a significant cost savings, like there was for my M4700.
As far as weight goes - it's a lot easier to add weight to the tractor for more traction. It's more difficult to strip down a bare tractor.
/ Too much tractor? #5
In the meantime, a local western store and trailer dealer has been buying and reselling tractors, mostly from individuals. He just bought a MX4700 with a 7 foot cutter from an individual and I'm going to look at it today.
All this to ask: is 47HP too much? Is an MX model too big? Is the MX too much tractor for my needs? Besides frame/tires, what other differences are there between the L and MX?
An MX will not fit in a garage with an 84" entry height, even with ROPS folded.
You will need 50 gross engine horsepower to operate a seven foot R/C in fairly long grass.
Standard L's and MX are both produced to hit competitive price points. The primary difference is weight rather than kit.
In terms of size, an MX is only 9" longer than L2501/3301/3901.
An MX is 15" wider than L2501/3301/3901 due to quite large wheels/tires on the MXs. MX tractors have larger front wheels and tires than the Grand L series.
Certainly ample tractor for seven acres.
New operators may be intimidated by size for first 20 engine hours, offset by feeling of great stability from weight.
/ Too much tractor? #6
I have the m5700 and I put it in my garage ( 84" opening ) as I have flat land and took off the top part of Rops .
/ Too much tractor? #7
You will need 45 to 50 gross engine horsepower to operate a seven foot R/C in fairly long grass.
Standard L's and MX are both produced to hit competitive price points. The primary difference will be weight rather than kit.
Jeffy, what is kit?
What is kit? My MX is less that 7 ft, ROPS folded. And the MX has considerable wheel width adjustment.
Can't always quote a specification, preferably owning the tractor allows greater accuracy
/ Too much tractor?
Just got back from looking at the MX. 675 hrs, 2012. The motor is in very good condition, bucket was a little bowed on the bottom, 3-point looked good. Didn't see any leaks. Had a little strange vibration/shimmy from the rear end while running about 7 or 8 mph across gravel. Not sure if that's an issue or not - really needed to drive it on pavement but couldn't.
Certainly a no-frills, get-it-done tractor. Not worried about parking it, ROPS up or down, I don't have a garage. Planning to add an extension on the side of the barn to cover whatever I get. Not sold on it yet - going to try to look at the L4400 on Monday. He said he's had 4400s too, a little smaller, not as wide, a little lighter - what I'd expect...pretty much echoing what's been said here. For about the same $$, the 4000 has about 500 hours less, so it's not really coming down to price.
/ Too much tractor? #9
anewuser.
If the mx has been sitting and it had nylon tires, They develop a small flat spot on the bottom of the tire, Not really noticeable on soil surfaces but on a hardened surface, yes. After they warm up a bit, the roundness returns and symptoms disappear. Probably more noticeable w/ non-loaded tires. Takes longer to resolve in the winter, tire warms more slowly. Possible explanation? Slightly worse w/ industrial tread.
I had a 7 ft cutter, two much surface area for only two blades. Was glad to see it sold. An 8 ft, twin spindle significant less drain on hp.
/ Too much tractor?
anewuser.
Nylon? That's a new one on me, but then everything tractor is new on me! They are industrial, and non-loaded. Temp is about 85, warm enough for me, but not like the triple digits we had recently.
/ Too much tractor?
anewuser.
/ Too much tractor? #12
Almost all compact tractor tires are nylon reinforced rubber. Called bias ply. Large AG tractors usually wear radial tires like your P/U.
Time was all automotive tires were also nylon ply. My MX displays similar symptoms, not loaded, non-radial. If new shoes are ever necessary, they will be radial. Warm temp doesn't solve the issue other than they round out faster after driving on a hard surface. Adding SSQA no biggie, done it to two of my loaders.
/ Too much tractor? #13
I’m in a very similar situation as the OP and have eight acres to maintain. The three tractors I’m considering are the Kubota L2501, L3560, and the Yanmar YT235.
Doesn’t sound like the heft of an MX is required and a 60” wide tractor may be a more handy size and easier to transport with his half ton truck.
/ Too much tractor? #14
Hello anewuser, cross or bias ply tyres will usually get a flat spot when parked for some time.
My old mf178 used to get flat spotted tyres after being parked for several days. You just drove off and after 200 metres the tyres were round again.
/ Too much tractor? #15
My B26 one time had a lope with a little side wiggle thrown in that I only noticed when travelling on pavement. I only noticed it once and immediately had to check all the lug bolts to make sure they weren't loose. Nothing found and the problem went away and has not returned. Flat spots on the tires must have been the problem.
Trailering your tractor (any tractor up to 50HP) should not be a problem with a 10K tow rating. I have trailered my LS P7010 a few times on my 20 foot 12K rated trailer using my 1500 Chevy Z71 as tow vehicle. It tows fine and likely outweighs any tractor that you are considering by several thousand pounds. I just have to position it on the trailer so as to not exceed the bumper tongue weight which is the towing limiter on my truck.
/ Too much tractor? #16
I think you're underestimating to power of tractors. A MX is one huge machine, ag grade and capable of doing most any task. But there are drawbacks, of course. Size matters. There's Too Big and Too Small. And every once in a while, there's Just Right.
From what you've described, I couldn't imagine anything larger than a L4400 being needed. I have 13 acres, mostly wooded, and a L3400 HST. Mostly 5' implements like tiller, box, blade, disc harrow, etc. except for a 6' landscape rake. Everything is sized to cover the tire tracks.
Of course, only you can decide what's best for your wants and needs.
There are many times that I'd prefer to be trying to squeeze a B-size tractor in places. Of course, I'm not trying to handle big rolls of hay around, but I'v never had to haul a log that couldn't be cut down to a manageable size.
/ Too much tractor? #18
By far what you are expecting to use it for the fel is the one that would set your standard I think. If you will be using a bucket withe logs then you need one large enough they will roll into for moving. As has been stated you should be able to cut them short enough weight is not the issue. You do have option for use forks or grapple which may handle larger diameter logs but watch their weight as grapple probably will weigh more than a bucket.
As to rear mower you would prefer it to cover outside to outside of the rear tires if reasonable but price mowers before you are certain what size you will go with for at least my pricing a foot is a monster in size and weight again to me compared to a six foot. Also price jump. Just do not see many around here for those reasons.
Odd the Kubota dealer sells all traded in tractors to a single source. Wonder why he would not want his name attached to them.
/ Too much tractor? #19
I once read on this forum "a small tractor can do anything and big tractor can, it will just take longer" that might be true for pto and 3 point attachments, just size them for your hp, 4 vs 6 feet type thing. BUT if you need to lift a 1500 lb bale of hay....you just cant do that with a tractor that can only lift 1000lbs.
my advice is dont worry about anything except FEL capacity and cost. the FEL capacity will stop you from buying something to small, and cost will stop you from buying somethign to big
/ Too much tractor? #20
That MX4700 would be a bit large for your 7 acres, except for your tree work. It is a good size for that sort of thing... big enough to manhandle logs around, small enough to get into close quarters. I used a similar sized Grand L to do nearly identical work for about 15 years. Getting something like that used can save money, but make sure it's in good condition.
"Kit": British slang for how well optioned somthing is.
Not sure why you need cutter or other implements > 6 ft. for 7 acres. 6 ft. size is a sweet spot in size/cost for smaller areages such as yours.
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
ASSET DESCRIPTIONS & CONDITION (A59914)
ASSET DESCRIPTIONS...
Crew Electric Golf Cart (A64127)
Crew Electric Golf...
2017 P.J. Deck Over Trailer, VIN # 4P5F82021H1265098 (A65563)
2017 P.J. Deck...
2004 Sterling Ambulance Truck, VIN # 2FZACFCS24AM53402 (A65563)
2004 Sterling...
Cat 312 Excavator (A62679)
Cat 312 Excavator...
