Wire feed welder
/ Wire feed welder #11
This thread prompted me to do a search on "wire feed welders" and brought up what is to me a scary article.
The 4 Best Wire-Feed Welders
Wire-feed welders let you conquer the world of metal, whether your reattaching the feet to a fireplace grate or fixing the broken axle on a trailer
4 Best Wire Feed Welders - Entry Level Welders Review
Please don't get a 120V welder to fix a broken axle on a trailer and drive on the road in front of me. Unless you are a VERY GOOD welder. I've been driving and had a wheel w/tire come flying off a boat trailer in front of me and hit my van. Not nice.
MIG can make pretty welds, MIG can make strong welds and weak welds that look pretty.
/ Wire feed welder #12
This article is an excellent example of why you shouldn't get your welding equipment and information off the internet. Find a brick and mortar local welding supply you like. Find a knowledgeable local to buddy with and learn by doing with the good stuff. Just say no to Amazon and Harbor Freight.
Your "weak welds" comment is another way of saying "too small, crappy welder gives inadequate penetration." Buy a name brand quality machine of sufficient size. They're easier to learn with and parts and consumables are readily available.
Trailer axles are not vehicle axles. Instead of medium carbon low alloy, they're often basically just a mild steel pipe and easily welded.
/ Wire feed welder #13
Boy do I feel like the rookie here. I bought a 90A 120V flux-core wire-fed welder from HF a few years ago (<$100). Cranked up to 8 on the wire speed, and using the 0.035 wire, I was able to get plenty of penetration to reattach the rusty blade arm to the 3PH frame on my scraping blade. It's all I had to fix it, and if it didn't hold, not much lost.
I used a HF grinder to clean up the original busted/rusted weld and had at it. I beat the crap out of it since, and no sign of it letting loose. Maybe I'm just lucky, but I'm OK with the results, and while I wouldn't use it on any life-critical things (like axles), I can't think of any other fixes/fabs that I would do with it that would see more abuse than the scraper blade fix.
/ Wire feed welder #14
<snip>
Your "weak welds" comment is another way of saying "too small, crappy welder gives inadequate penetration." <snip>
No, it was a way of saying it looks good but the operator did not have enough experience to make a good weld with penetration and did not check the penetration. From my readings the only way to really check the penetration is to cut through the weld or beat the snot out of it.
I've seen many pics of pretty mig welds on here and elsewhere that were a little better than hot glue. And I'm sure one could make a pretty MIG weld with a $2,000 machine and not get penetration.
And I'm pretty sure Shield Arc, who only has few weeks of experience (or so he writes :) ) could make good welds on truck axles with coathangers and a car battery if he had to!
/ Wire feed welder #15
Most of my welding is with a 220 amp Hobart and I never had any failures.
6013 is my 'go to' rod.
Not long ago I sprung for a cheap wire welder for very thin materials.
Works so-so but sure splatters a lot.
Is that the norm? or is it the wire they provided.
Also I find the wire feeds out much too fast, that or I am too slow.
I had developed a technique with the Hobart whereby I'd sort of do small 'spot welds' on thin stock but more often than not burn thru every 5th or so 'spot'.
That is what prompted me to try the wire machine.
LOL also discovered not to weld close to dinner time as the circuits seem loaded.
/ Wire feed welder #16
A very large part of a good strong weld is preparation and fit up. Good penetration is not based solely on size/power of the welder.
Just like owning a sub compact tractor doesn't limit you to only cutting grass.
Yes. More power makes things easier and faster but not necessarily better.
/ Wire feed welder #17
That's a very good point. I was so proud of myself for getting that scraper blade back together in a way that actually held well, that I thought I'd treat myself to a "real" welder. But, before I could pull the trigger, I realized that for the odd and infrequent things I weld, this little Fisher-Price HF thing seems to work ok for my needs. I guess my point to posting is this - if someone considering getting a welder, they might not want to dismiss the smaller, cheaper HF toy welder, as it really does work surprisingly well - even in a novice's hands.
That said, I'm sure if I ever use a $1000k+ welder, I'd never go back, but given the results of my $90 welding experience, I cannot justify it.
/ Wire feed welder #18
I like E6013 too esp on new steel. Every mig wire has a higher tensile and is more ductile than the stick rod you will use. It is stronger than mild steel and most are as ductile. (In practical terms, everything you weld is designed with a safety margin and 10000 values difference off some chart will not matter much.)
Some of the things to leave off when you build a cheap welder: full wave rectification, huge capacitor bank to smooth ripple, a stabilizer (hunk of iron with copper wire wrapped around it)
Body shops do the same thing with wire machines on too thin panels.
I just like this quote and wanted to read it again.
Quoting is easier than repeating .
I am not a CWI but part of knowing what looks good is checking for joint prep, checking back side for penetration, checkinG bead appearance to estimate amperage appropriate for material thickness. X-rays and bend tests are not required.
Tough to do any of the above on the internet.
/ Wire feed welder #19
At first glance,a lot of the opinions posted seem contradictory but in reality most aren't. I'm fairly new to welding and here's my take so far. Buy a name brand machine,buy 240 volt or dual 120/240,get the most amps you can afford but at least 175. You can't buy parts for HF and other low end machines. While it's true good looking mig welds can be weak,mig can make as strong of welds as stick. Try breaking pratice welds if there's any doubt. Newbies will do themselves a favor starting off with flat & horizonal wire rather than the popular all position wires. After getting comfortable doing flat & horiz,go with all position if you occasionally need to do vert or overhead. Rather than striving for stack-o-dime appearance,try eliminating worm holes, inclusions,undercut,lack of penetration and burn through. I have been happy with my Lincoln Pro-Mig 180 doing body panels,pipe H fence braces and in between.
/ Wire feed welder #20
Maybe welders at Kubota and Land Pride should read this thread. There are welds on my tractor and my box blade that wouldn't have passed in my back yard let alone a factory.
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
Giyi GY-QSJ Mini QA Broom Sweeper (A60463)
Giyi GY-QSJ Mini...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60352)
2018 Freightliner...
Iron Bull Trailer (A60462)
Iron Bull Trailer...
2019 Bobcat MT85 (A60462)
2019 Bobcat MT85...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
