3-Point Hitch furrow plow to big
/ furrow plow to big #1
coupman35
Gold Member
Northen Ontario
Now a L4060 had B2650
Just pick up this nice massy furrow plow today. When I got home started to look at it closer and notice the 3 pth are to big for my b2650 the pin are 1 1/8 big and the plow is very heavy . Now wondering if I can make it fit , can my tractor pull it whit 003.JPG001.JPGhout braking anything. The plow a model 70 3 furrow. what do you think
/ furrow plow to big #2
Unless you have light easy pulling soil I doubt that a Kubota B2650 would pull a 3 bottom plow.
Not sure but it might lift it.
/ furrow plow to big #3
You could always remove one of the plows (left side) from the frame. The Cat.II pins are your big problem.
Myself, I would look for a better set of 14" two bottom plows with Cat. I hitch pins. Smaller and lighter, which would make it a much better fit for your Kubota.
/ furrow plow to big #4
I don't think this is going to work. It's wayyyy too much plow for your tractor. If you can get it attached to the tractor I don't think you'll be able to lift it more than a few inches off the ground at best. Your lift arms are going to be most of the way up by the time to hitch it.
If you park your tractor beside this plow it will start weeping..... ;)
Edit: I pull this same plow with my Ford.
/ furrow plow to big #5
Nice looking plow-but way too big for any B. 2-12" plows are all that are recommended for my L3560.
Will
Thanks guy I but the plow back up for sale .After seeing how big it was beside the tractor I was sure it was to bit. So tomorrow am going to see a 1 furrow massy plow I think this will be a better plow for my tractor.
/ furrow plow to big #7
Or a good reason to get a bigger tractor.
/ furrow plow to big #8
Just pick up this nice massy furrow plow today. When I got home started to look at it closer and notice the 3 pth are to big for my b2650 the pin are 1 1/8 big and the plow is very heavy . Now wondering if I can make it fit , can my tractor pull it whitView attachment 563315View attachment 563316hout braking anything. The plow a model 70 3 furrow. what do you think
Nice plow, and I'd like to have it but it's about 3 times too big for your 2650. Indeed, my L6060 with draft control would not touch that plow in my ground.
If you really want to plow with a 2650, look for a 1X12 plow. Better yet, get a roto tiller.
SDT
/ furrow plow to big #9
Way to big a plow for a compact tractor, even 2 bottoms are to much for a 2650. Since its already yours take 1 bottom off and make a new frame save the other 2 bottoms for parts and scrap the rest.
I had a 2x14 rope trip trailer plow I converted to 1 bottom and 3 pth, did a fine job plowing.
/ furrow plow to big #10
I did the same with an Allis Chalmers that I converted to 3pt hitch, does a good job. I would like to see some pictures of yours.
Kubota BX22 Plowing the garden - YouTube
/ furrow plow to big #11
The plow is Cat 1. The tractor is Cat 0.
Well here is what I pick up yesterday for a good price 100.00$ .The front wheel was not on it I had one here look like it going to work and I just had to paint it orange you can call it massy orange lol.
/ furrow plow to big #13
There you go much better!
/ furrow plow to big #15
The plow is actually Category II as the OP stated the pins are 1.125" diameter. Category I is 0.875"
Nonetheless, the plow is too big for the OP's tractor. A single bottom 14" (preferred) or a 2 bottom 14" (ok) would be better.
The old 19hp Farmall C can pull 2-14's.
The new single bottom plow you got is nice! I have the same one but a little older...my A-frame is all cast iron where yours is fabricated steel. The front "wheel" is called a coulter, by the way! I just re-bushed the furrow wheel on mine last week...check to see if it's wobbly on its shaft. If it is, you need to bore it and install a bushing...it's just steel on steel with a grease fitting. I ground the rivets off the hub, chucked it up in the lathe and indicated it true, bored it out then made/installed a new bushing with a very LIGHT press fit...worked like a champ.
/ furrow plow to big #16
Nice , and your 2650 will be much happier .
yep am sure it will .I dont like to abuse my stuff . I know it can take a lot but like to take good care of it .
/ furrow plow to big #18
:thumbsup:
/ furrow plow to big #19
OK, let's see it in action now. Drop that thing in the dirt and let it rip. Did you mention what implement you will be using after the plow and what you'll be doing with the ground after it's worked?
Kevin
Soon it to dry right now ,I try it a bit when I got it I cant wait to give it a real try .I just got a piece of land in the back yard about 100 x 200 that id like to get nice and strait afteram done plowing I have a set of disk that am going to run over to brake it up. Am planning on doing a RC track for the kid well and me.
2014 Caterpillar CB54B Articulated Vibratory Tandem Smooth Drum Roller (A61572)
2014 Caterpillar...
ALLEN AR16 BUGGY (A63569)
ALLEN AR16 BUGGY...
Pallet of Safety Cones (A64047)
Pallet of Safety...
2024 DEVELON DL250-7 WHEEL LOADER (A63276)
2024 DEVELON...
2018 FREIGHTLINER CASCADIA  125 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
2011 Ford F350 Flatbed Dually Truck (A64047)
2011 Ford F350...
