3-Point Hitch furrow plow to big
   / furrow plow to big #1
coupman35
Northen Ontario
Now a L4060 had B2650
Just pick up this nice massy furrow plow today. When I got home started to look at it closer and notice the 3 pth are to big for my b2650 the pin are 1 1/8 big and the plow is very heavy . Now wondering if I can make it fit , can my tractor pull it whit 003.JPG001.JPGhout braking anything. The plow a model 70 3 furrow. what do you think
   / furrow plow to big #2
Unless you have light easy pulling soil I doubt that a Kubota B2650 would pull a 3 bottom plow.
Not sure but it might lift it.
   / furrow plow to big #3
You could always remove one of the plows (left side) from the frame. The Cat.II pins are your big problem.
Myself, I would look for a better set of 14" two bottom plows with Cat. I hitch pins. Smaller and lighter, which would make it a much better fit for your Kubota.
   / furrow plow to big #4
I don't think this is going to work. It's wayyyy too much plow for your tractor. If you can get it attached to the tractor I don't think you'll be able to lift it more than a few inches off the ground at best. Your lift arms are going to be most of the way up by the time to hitch it.
If you park your tractor beside this plow it will start weeping..... ;)
Edit: I pull this same plow with my Ford.
   / furrow plow to big #5
Nice looking plow-but way too big for any B. 2-12" plows are all that are recommended for my L3560.
Will
Thanks guy I but the plow back up for sale .After seeing how big it was beside the tractor I was sure it was to bit. So tomorrow am going to see a 1 furrow massy plow I think this will be a better plow for my tractor.
   / furrow plow to big #7
Or a good reason to get a bigger tractor.
   / furrow plow to big #8
Just pick up this nice massy furrow plow today. When I got home started to look at it closer and notice the 3 pth are to big for my b2650 the pin are 1 1/8 big and the plow is very heavy . Now wondering if I can make it fit , can my tractor pull it whitView attachment 563315View attachment 563316hout braking anything. The plow a model 70 3 furrow. what do you think
Nice plow, and I'd like to have it but it's about 3 times too big for your 2650. Indeed, my L6060 with draft control would not touch that plow in my ground.
If you really want to plow with a 2650, look for a 1X12 plow. Better yet, get a roto tiller.
SDT
   / furrow plow to big #9
Way to big a plow for a compact tractor, even 2 bottoms are to much for a 2650. Since its already yours take 1 bottom off and make a new frame save the other 2 bottoms for parts and scrap the rest.
I had a 2x14 rope trip trailer plow I converted to 1 bottom and 3 pth, did a fine job plowing.
   / furrow plow to big #10
I did the same with an Allis Chalmers that I converted to 3pt hitch, does a good job. I would like to see some pictures of yours.
Kubota BX22 Plowing the garden - YouTube
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
1994 Blue Bird School Bus (A55973)
1994 Blue Bird...
flatbed trailer 24ft (A56857)
flatbed trailer...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2015 FREIGHTLINER M2 BOX TRUCK (A58017)
2015 FREIGHTLINER...
2024 FORD F250 SUPER DUTY BED (A58018)
2024 FORD F250...
