Loader BX2380 Quad Hydraulic FEL disconnect leaking?
/ BX2380 Quad Hydraulic FEL disconnect leaking? #1
glenk
California
BX2380
Anyone have an issue with this assembly leaking (slow) and dripping on their driveway? Any fixes such as reactuating the assembly?
Tnx,
/ BX2380 Quad Hydraulic FEL disconnect leaking? #2
Warranty repair, noted on orange forum.
/ BX2380 Quad Hydraulic FEL disconnect leaking? #3
I do not have a BX but all my hydraulic systems with quick connects drip a little. I try not to run them on the driveway any more than need be. Our rain washes away hydraulic drips faster than engine oil drips, so it is not much of an issue to me.
/ BX2380 Quad Hydraulic FEL disconnect leaking? #4
I tried to find a reference to a warranty repair and found nothing so far, any chance you know where that can be found. The Kubota rep says he has never heard of a leak like that, pretty common response from someone that doesn't give a Schmitt.
/ BX2380 Quad Hydraulic FEL disconnect leaking? #5
glenk can you tell if its leaking right there at the clamp or if its leaking further up and just running down the lines? The reason I ask is that the service tech who did a recent service on my bx said that where the lines attach to the coupler base itself can loosen up but all you have to do is snug them up again.
/ BX2380 Quad Hydraulic FEL disconnect leaking? #6
I know where the leak is coming from, the coupler assembly becomes misaligned when the hydraulic pressure is high. It seems to be caused by the fact that the single cam lock doesn't keep the assembly together properly at high pressure, without much load on the loader there is seldom a leak. My quest is to find out if Kubota has a warranty fix for this problem, before the machines I have are out of warranty. Kinda like the schmitty seat campaign for the BX2200, if you complained within a certain time period, Kubota would furnish a better seat, I had to buy one, I wasn't aware of the campaign at that time. I learn from some of my mistakes.
I don't know of any formal recall campaign. I just complained and showed evidence of the leak to my dealer. Any severe leak like this is not acceptable. I couldn't park in on my driveway or garage. They tried their best to tighten fittings, redo the coupler pipe thread connections but it still leaked. I have been busy with the tractor so I elected to live with it by stuffing paper towels under the assembly until my 50 hour service. Which has just come up. They have a complete set of hydraulic couplers to install, waiting for me.
The single lever does not firmly clamp the two coupler sections together. It shifts under load and the distortion of the loader arms going up and down with load.
I complained directly to Kubota on their website. Said I should have bought a John Deere and they responded right away and contacted my dealer to solve the issue. We shall see. I'll update it after I get them serviced soon.
/ BX2380 Quad Hydraulic FEL disconnect leaking? #8
I've owned several Kubotas in the BX and B and a couple in the L series. I've had some start leaking a drop or two at a screw on fitting and the slightest turn with an open ended wrench has always stopped the leak. I recently had a line "BLEW" and I mean BLEW like a geyser because the turn in the line was right at the crimped on fitting and when the FEL would work it twisted the line right at that crimped spot. I replaced the line and adjusted the turn so the twist/movement when using the FEL bucket is in the middle of the line and not at the edge of the crimped fitting. I had one years ago that rubbed a spot on a hose every time the FEL was used and the protective sleeve was misaligned and I never noticed it but I never suspected a hose would rub thru and become useless. Always made sure the protective sleeve covered the spot after that. I've never had any Kubota that dripped or leaked that I parked on the drive way with it leaking/dripping/dropping a dot of hyd fluid other than the ones previously mentioned which I tightened and stopped the leak. Should be no leaks or drops on a good connection/fitting. Finding a drop of fluid is a warning something isn't connected right or a fitting is bad or some other problem with a system where oil, water or hyd fluid is involved.
/ BX2380 Quad Hydraulic FEL disconnect leaking? #9
The leak you describe is not an endemic problem. We have changed one manifold half due to leakage caused by factory personnel crossthreading the tube fitting.
/ BX2380 Quad Hydraulic FEL disconnect leaking? #10
I read comment #2, it mentions a warranty repair sited on another forum, I wasn't able to find anything. Maybe they have an updated coupler assembly to install on your machine? A cam lock on both sides would probably hold the coupler halves together and eliminate the leak. All I have to do is hold the loader lever until it goes to pressure relief and the coupler halves separate without the loader arms moving.
I wouldn't even consider a Deere though, I had to run a 2 cylinder John Deere as a kid on the farm, that thing should have been shoved up someone's azz.
/ BX2380 Quad Hydraulic FEL disconnect leaking? #11
My neighbour had his replaced about 6 weeks ago. Then about 4 weeks ago mine started leaking. I've been waiting and waiting for the replacement since the. They are now on back order with no date as to when it will be available. I would've thought that Kubota would be making an effort to increase production and availability of these things.
/ BX2380 Quad Hydraulic FEL disconnect leaking? #12
I purchased my BX2380 in May of 2017 and I did have problems with the quad hydraulic FEL disconnect leaking sometimes. The leak was from a few drops per day to drops per minute.
A couple of months ago I had the machine at the dealers and I asked about the leaking connector. They showed me a service advisory indicating that there was a problem with a leaking coupler on the BX2380. The service advisory was not a manatory recall but was a fix if the customer complains.
They changed the coupling and I have had no leaks since then. No charge.
/ BX2380 Quad Hydraulic FEL disconnect leaking? #13
I recall some brief discussion on this over on Orange Tractor Talks forum. As GordonE points out, there is a service advisory to fix leaking couplers. Sounds like your dealer is ready to fix it when you go in for your 50 hr service.
I've had no issues with mine leaking, ever. I R&R my FEL quite often also, but am always careful to wipe everything off before reconnecting.
Tnx,
glenkView attachment 563452
The quad upper block assembly that comes off with lever was replaced on mine. It seems to have solved the leaking problem but I haven't done a lot of FEL work since then. I will be doing some shortly and will update the thread.
I was using the FEL pretty hard. I moved a dry mound of 2-3 yards of clay rock and soil and then leveling the area afterwards. Happy to say, it didn't leak at all.
The only further test would be to disconnect the quad coupler and reattach to see if still stays dry. For some reason, I'm hesitant to do that...
/ BX2380 Quad Hydraulic FEL disconnect leaking? #16
Have same exact problem. Started just as some drops here and there. Very recently turned into a complete run. Will talk to my dealer about what you mention here. Picture attached. It's one of the 4 qds pouring out even when it appears seated.
/ BX2380 Quad Hydraulic FEL disconnect leaking? #17
Worse when connected and motor running. Lost 2 gallons of oil.20200516_153214.jpeg
Worse when connected and motor running. Lost 2 gallons of oil.View attachment 656317
Wow, that's a lot of fluid. Also quite a few $$ to replace just the fluid alone. Is the leak coming from the gap between the upper and lower quad coupler assemblies?
After a year of use, mine still seeps fluid. I think the dealer tests the repair just by cycling the FEL through it's motions. That does little to stress the FEL mechanically. You have to be digging, lifting, stressing the FEL arms horizontally.
Hope you can get yours fixed soon!
/ BX2380 Quad Hydraulic FEL disconnect leaking? #19
Holding each function at both full extension and full retraction forces each connection of the manifold to bear the full relief pressure of the hydraulic system. That is as valid a test method as is required for leak testing.
For pressure I agree. But not for physical stress to the FEL arms and tractor chassis is where you are putting stress on the quad coupler and it's retention mechanism. It may be small movement but somewhere in one of the Kubota tractor forums there is a video of that assembly moving as the FEL moves. That's what I wonder is happening to create the leak. Mine was dry after the repairs and the retention mechanism has never been released since I got it back, yet it still seeps fluid. Maybe it's the repeated movement of the FEL over time and changing pressure on the retention mechanism. I just don't know.
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
2017 Ford Fusion Hybrid Sedan (A61569)
2017 Ford Fusion...
Pair of 2001 XA800Z Yamaha Jet Skis (A61166)
Pair of 2001...
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
2020 MACK GRANITE (A60736)
2020 MACK GRANITE...
8'X28" Table with sink and dishwasher inlet (A60352)
8'X28" Table with...
