Rotary Cutter Rotary cutters suggestion
   / Rotary cutters suggestion #1
m1garand762
Gold Member
ohio
kubota
I am looking for a new rotary cutter. I have narrowed it down to the Everything Attachments heavy duty cutter 60 inch, the Woods bb60, or the Landpride 1860. I am not considering cheap cutter so dont wast my time with tsc special and crap like that. it need a 2 inch capacity mower that will be here in 50 years and take some real abuse
   / Rotary cutters suggestion #2
I'm sold on Woods Rotary cutters, but I wouldn't consider THAT model to be a HD cutter that will be here for the next 50 years... lol
It's a good cutter but it's sure not one of their HD cutters!
SR
   / Rotary cutters suggestion #3
Woods.Bushog,Brown are the toughest I have seen. EA cutter is a good deal.
   / Rotary cutters suggestion #4
50 years on a bb60 or a 5ft land pride?? Lol
Not..
Bush Hog or Deere MX are about as rugged as you can get in 5ft mower. Never saw the everything mower.
   / Rotary cutters suggestion #5
Not..
Id take that bet with a LP 2660. Had one and upgraded to a 2672. **** im still using a unknown brand 5 footer from the early 70's that is no where near as HD as a 26 series LP.
   / Rotary cutters suggestion #6
Woods makes three versions of their brush bull cutters, the heavy duty 5' BB6000x weighs a little over 1300 lbs, the 5' BB600X weighs 1,000lbs., and the 5' BB60X weighs 600lbs. Quite a difference between metal content between the 6000 model and the 60.
I'm sure other top manufacturers have same size cutters with different duty levels of construction. Landpride has their smooth top heavier version like the Woods Brushbull which is model RCF2060, it has the 2" cutting capacity.
Woods even has their lighter, and less expensive, duty Heritage line.
Maybe you should consider the Woods BB600 or BB6000 or the Landpride RCF series for their heavier duty construction, cutting capacity and durability you are after?
Having said all that I have a Woods BB72X and it works for my use.
   / Rotary cutters suggestion #7
What kind of tractor are you planning to use to abuse the cutter?
   / Rotary cutters suggestion #8
Excellent post. When comparing implements, you must consider the various models or series, not just the brand name alone.
   / Rotary cutters suggestion #9
SR
He said bb60, LP1860, the mowers your talking about are whole different animals..
   / Rotary cutters suggestion #10
My above post was meant for this one..
KUBOTA M955 DUAL SPEED TRACTOR (A57192)
KUBOTA M955 DUAL...
Metal Bigfoot Lawn Art (A55853)
Metal Bigfoot Lawn...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
Cushman Electric Cart (A55853)
Cushman Electric...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A54814)
2003 Pierce Tilt...
