Three point electrical control problems on Branson 6530C
/ Three point electrical control problems on Branson 6530C #1
dclt736
Oxford Mills, Ontario, Canada
Banson 6530C, John Deere 1120
I have a Branson 6530C which I purchased used a few months ago and I am trying to trouble shoot an electrical issue with the three point hitch system.
The mechanical lever for height is working fine, however I have no function with the toggle switch up/down. Also the dash light for the three point hitch is showing up all the time regardless of the setting on the link arms. I have tried some debugging, and the up down switch seems to have the open close electrical path I would expect. I know that the system uses an electric motor under the cab at the rear to do this work, but before I start to remove it and see if that is a problem, I was wondering if anyone has run into problems on their own units and might have some suggestions. I want to plough some land this summer and having to control the deep without the electric control switch could be a problem. Fuse and relays have all been tested and changed around, with no operational change. Also the auto lift switch lights up when pressed on but no arm lift on turning corners. Thanks.
/ Three point electrical control problems on Branson 6530C #2
Will reply tomorrow.
/ Three point electrical control problems on Branson 6530C #3
Currently editing what I sent earlier this morning: It's 2 pm Saturday afternoon, June 30. I am reading and updating this as I learn about the system. It's really hard to instruct you from the manual, interpreting the translation, and relay my experiences.
I just changed my mind due to the complexity of what I started out to do this morning.
I just erased the wires, names, and connector pinouts, resistance readings and locations of the components in just part of this system. What needs to be included is the interaction of the operator in using the tractor to get the when and why response and that gets messy. Reason is that this reply of mine would be pages long and without pictures would be extremely complicated even for me to understand what I may have thought I sent to you.
You really need a "Chassis Service Manual" for the 6530. With that in front of you, if you need help, we can dialogue and possibly make some sense of this.
We are going from two switches on the control panel, through switches associated with the actual position of the 3 pt arms external to the cab, including the internal and external Position Control lever's positions, routing back through the steering column to pick up the shuttle shifter position (Reverse), and on to the instrument panel to the "Auto Backup" module where the light is located you mentioned.
The manual, although translated somewhat and somewhat foreign in terms and all does show pin numbers, location of the pin numbers in the plug/socket interconnects, the color codes of the associated wires and a module by module wiring diagram. Takes some time to digest it but it seems to be all there. What's missing is the when and why of the operator intervention into the operating of these parts.
If you can't find a dealer from which to purpose, might just www to locate one or I can put you onto the Plainview, Tx. Site where I have gotten super service, or several dealers in my area eager to help.
Good luck,
Mark
/ Three point electrical control problems on Branson 6530C #4
Good luck,
Mark
Still thinking about this. The fuse is # 09 and is labeled BACK-UP. Lower right corner of the fuse panel cover diagram. Pull the fuse and everything associated with the Back Up circuit will be disabled including the light and toggle switch.
The real workhorse in the automatic circuit is the "Back Up" Relay in the relay panel just behind the fuse panel. All the parts to this puzzle seem to be tied together in this relay and being a relay, with all the problems you indicate, well could be your smoking gun. Second would be the parts associated with sensing the position of the lift arms outside due to possible weather damage.
Your manual positioning concern was setting the depth to a preset value when you drop the position control. There are two interacting position controls, the one on the control panel inside the cab and the one out back adjacent to the 3pt (orange knob). That sets your depth regardless of anything else.
Set your manual position control all the way down on the control panel. Go out back and set your implement depth with that one. Your manual control will still raise and drop your implement but it will only drop as low as the outside one will allow it.
A point to consider when you turn off the tractor for the day. You lower the position control, but the implement (may be...depending on where you set it) is still off the ground....you don't want your implement suspended for any length of time...hard on the packing cylinder controlling the 3 pt.
Just go around back and lower that position control lever and lower the implement.....course you have to reset it the next day.
When I was looking for a tractor, that one thing, the outside 3 pt controller (that nobody else had when I was shopping popular colors 6 months prior and just gave up), was what started my purchasing process on the Branson. That I said is a "gotta have" and started being briefed on what else comes with it. Course the lift arm extensions and the tube pin stabilizers and....and.....and
/ Three point electrical control problems on Branson 6530C #5
Helloooooo. You still there?
Yes, sorry about the late reply Mark, I am in the middle of haying up here and every minute of the day is consumed, and what with the heat wave we have having, we have been loading and unloading much later in the evening to save ourselves.
As for all your advice, I will look into the relay, one thing I will look for is to see if the dash light goes out.
The owners manual states that it will come on at start up, but go out after 3 seconds, and that doesn't happen now, it is on all the time.
So when the relay is pulled and the light stays on, then that may be tied to some computer chip that turns the light on as a blub test mode but does turn it off.
I do have a feeling that it might be something in the electric motor.
Another thing I noticed is that they talk about (owner manual) a lock for the control levers, and there is a third cut out in the plastic panel for the draft and raise slots, but nothing in it. Is it possible that there is something missing there?
I will take a photo of my plastic to upload.
Again as I am in hay mode and working full time to make a living, I may not be able to dive very deep into the investigation for a week or two, but want to thank you for support to date.
Also I do have the service manual, which I purchased from Branson just after a got the tractor and started to work on it.
The electrical diagrams are there, I will scan and attach but they do leave some information missing, and I am still trying to workout how the some information is show on the electrical drawings.
And have a great Independence Day tomorrow.
Douglas
/ Three point electrical control problems on Branson 6530C #7
Douglas
I'm a former resident of Quebec and later on, Western New York.
A heat wave in Ontario? What are the daytime highs?
I hope Canadian Independence Day was a good one for you.
Day time highs 34-38 celsius range, tomorrow forecast for Ottawa is 35c (96F), humidex of 43c or 109F, just great in the sun throwing those bales onto the wagons.
Been this way since early last week.
Showing cooler weather for a few days come the weekend.
Above average for sure this time of year.
Douglas
/ Three point electrical control problems on Branson 6530C #9
Douglas
Wow those are historical temperatures I would think.
Keep your fluids up and in the shade as much as possible.
Best regards.
Will do Bob, weather is set to return to more normal ranges this weekend.
Douglas
Hi Mark
I have scanned the electrical sections of the service manual.
Only problem the way I scanned it, the pages are not all in the same direction.
If you print it out, single sided you should be ok.
Also note that the sheet size is A4 I think, so you will need to scale to fit standard letter size.
Also here is a photo of the plastic panel with the 3 point arm control levels and the third empty slot.
I haven't tested the relay removal yet, still working to finish off my hay, which if all goes well, I will be done first cut this weekend.
Douglas
  • Chapter 6 electrical Branson 6530C.pdf
/ Three point electrical control problems on Branson 6530C #12
Hi Mark
Douglas
The slot is for a sliding, knurled nut operated, lock for setting the lower limit for the position control. I never used it because if you slammed the control too hard it would move. The one outside rear is bullet proof and it's probably missing because the PO agreed with me and took it off.....good riddance.
I have my manual on my desk here in the house. Just tell me the page/item ID and I'll follow your questions.
Hi Mark
Thanks for that information.
I will start to look at the diagrams and make a short list of questions, but most likely that will not be until mid next week, still working at the hay here and until I get that done with, I have limited time to park the tractor and get it ready to start the debugging process. Looking forward to finding out what the issue/fault is and fixing it.
Have a great weekend.
Douglas
/ Three point electrical control problems on Branson 6530C #14
Hi Mark
Douglas
I'll keep an eye out.
Hi Mark
Here is the page of the wiring diagram for the back up control of the three point hitch.
I have circled in Red five items which apply to the questions below.
A-does the light on the switch come on only when the back up is turned on?
B-what is this block and where is it located?
C-any idea of where I should look for this diode assembly
D & E what do these letters indicate, other then the continuation of the wiring, do they tell me somewhere else to look?
I am going to pull the seat out over the next few days, as I understand I will have better access to the up/down motor and wiring from a panel under the seat.
I wonder if there is some sort of wire damage etc, like a short, as the 3 point hitch lamp in the dash cluster is on all the time and it seems to look like if a wire was grounded it might be the cause for that.
And other suggestions.
Thanks
Douglas
/ Three point electrical control problems on Branson 6530C #16
Hi Mark
Thanks
Douglas
I have the Branson badged, high back air seat. To get it out I tilt it back as far as it will go and pass it out thrugh the rear window. Goes out quite easily.
A pinched wire is always a possibility.
A rat ate through the insulation at the wrong place is also a possibility.
The relay is a central point but relays are "traffic cops" of a sort: You have 2 or 3 contacts so you either have ON-OFF control or you have direction control...common to circuit A or common to circuit B. You could have 20 "sets" of contacts in one relay and none of them are related other than when the relay changes positions, all of them change position.
The above is why I don't think the relay alone is the culprit unless it had a catastrophic failure where a contact mounting within the relay broke and the contact fell on an ill intended circuit.....but that wouldn't be several ckts.
I'm busy right now but I'll look at it later today. Meanwhile you dig around and see if you have any rat poop around, first thing to consider when they visit....or nesting material, or little piles of junk (pack rat....had one recently).
Hi Mark
I started at it last night, removed the seat to get to more controls as well as opened up the right plastic cover to get to the up/down switch etc.
What I know for sure now.
The up/down switch is good, contacts open as close when they should.
Lift switch, at the left upper link arm is also good.
The item B in the diagram turns out to be a circuit board located in a plastic housing under the seat floor. So I opened it up as well, and didn't see anything out of place, ie burnt traces, discolour components etc. Does mean it is good, but without more skills, I will not know.
The push button for the auto lift is working somewhat, it is a little weak so I have called the dealer to get a price on a replacement.
I will test the front axle turn switch tonight, and also power up the system and start to see where I find voltage and where I don't. The system seems to show that the up/down switch control should still work if the relay control board is acting up, but testing will hopefully tell me more.
As for mice/rat damage, I have had to deal with that in a past life, but I had a good look at the machine and have not seen any evidence of mice damage, however a pinched wire is still possible from simple wear and tear.
Will start tracing voltage tonight and see what that shows.
Hopefully I don’t set my tractor on fire.
:laughing:
Douglas
/ Three point electrical control problems on Branson 6530C #18
I printed off your progress thus far and am going over it.
Hi Mark
Had some better luck this evening.
I now have the UP/Down switch working and controlling the three point hitch.
But still do not have the auto lift function working.
I do think I found one of the problems, but am not 100 percent sure.
It seems that the back up motor connector is the same size as one of the connectors on the back up relay box and I think someone had them connected wrong, as after i had everything apart, i was confused myself as to what plug where, so using the wire colours worked it out. After that the Up/Down switch now controlled the back up motor, which in turn controlled the three point hitch.
However the auto up system is not right.
If i have the links in the down position and the auto lift off, as soon as i turn the auto lift one the arms will raise. I can them put them down with the up/down switch.
However after that, no turning of the front wheels or putting the tractor into reverse will cause the arms to lift like the system should. Also I believe that the control PCB is also part of the auto off PTO system and I don't have that working either.
I am going to work as the front axle switch tomorrow to see if it is working, and also try and test the forward/reverse switch as well to make sure they are working correctly.
Looking at the drawings, i should find 12 volts to one side of that front switch when the auto up is on, correct?
Thanks
Douglas
/ Three point electrical control problems on Branson 6530C #20
"I have circled in Red five items which apply to the questions below."
I corrected my response today from what I submitted yesterday. I better understand that the "Backup Relay Unit" is a separate assembly with an A and B connector. Shouldn't be all that hard to find.....see below for guesses as to where it is.
In answering your above questions:
A-does the light on the switch come on only when the back up is turned on? Yes.
B-what is this block and where is it located? Correction from yesterday after looking closer today: It's identified as the "Backup Relay Unit" and has 2 connectors, one larger than the other. Page 6-25 where you circled the what is it.......has the two connectors' pinouts with wire color codes, below and to the right of the thing you circled. They also show up on Page 6-28 at the bottom, identified as the backup controller A connector, with the pinout for troubleshooting, and on Page 6-29 at the top. These two charts may tell the story you are looking for as to is this relay functional or damaged in some way. Where is it located???? I'd guess somewhere in the wiring of the control console to the right of the seat. Second guess would be under the steering/instrument panel console where the brake shuttle connectors are or behind the instrument panel in that shroud that encircles it.
C-any idea of where I should look for this diode assembly? Correction from yesterday: May be part of the "Backup Relay Unit". Both diode assys, appear to be "inductive spike" clamping diodes protecting the contacts of the relay. Otherwise they are steering diodes for the different functional paths associated with 12v.....like when one function is being used, they allow it to be used but prevent it from interfering with another function not being used.
D & E what do these letters indicate, other then the continuation of the wiring, do they tell me somewhere else to look? D, aka your red Circled B is on page 6-30, Section F, Horn & Lamp Circuit...diagram, upper right area of schematic, provides ground to the "backup light relay" when you push the backup automatic button above the up down toggle switch.
E is on page 6-20, Section D. Warning Circuit, Diagram near the bottom, right of center. When it closes via the relay mentioned above, it turns on the dash "3 pt raised" amber lamp.
The sections of this manual pretty much lead you through each component at the connector and tell you how to trouble shoot it. What's missing is understanding the whole scenario since things are wired in series and....... this has to happen for that to happen or if that happens this will.......
The motor: First of all it's a slave component. It gets told what to do. It can be tested as shown and if not satisfied, I'd put 12 v across it and run it one way (just long enough to see it respond) and reverse the leads and run it the other. The enclosed relay symbol may be a built in limit switch on the motor to shut it off when it hits a limit to prevent motor burnout. That switch could be bad, but it and a bad motor have no bearing on your dash lamp remaining illuminated since it gets illuminated on the "move command", not on the results of where the "move command" told the motor to move.........."Person of interest" Relay popping up again.
If all that works, then I'd replace the relay in the "Backup Relay Unit".......apparently it's not one of the relays in the relay panel, above the engine, behind the fuse panel.
Most relays have part numbers on them and are www traceable. If it's plug in it's a no brainer. If soldered, I think you have shown me your electrical expertise so that shouldn't be a problem for you either.
Things are pointing toward the relay in the "Backup Relay Unit" and the reason is 3 key points of activity are wired through it and since they all don't work, the common denominator is the relay.
I think I typed what I think I understand. Keep me posted.
Mark
