What is user UNFRIENDLY on your tractor?
   / What is user UNFRIENDLY on your tractor? #11
Wish the digital dash had a clock.
   / What is user UNFRIENDLY on your tractor? #12
Wish mine had an oil pressure gauge.
   / What is user UNFRIENDLY on your tractor? #13
John Deere 2030, Collar shift transmission. You have to come to a complete stop to shift gears or ranges. But it's 44 years old
   / What is user UNFRIENDLY on your tractor? #14
Diff lock is operated by right heel. Unfortunately, your right foot is busy with hydro pedals, also on the right. Brake is all alone on the left.
   / What is user UNFRIENDLY on your tractor? #15
NO, B2920. diff lock left foot heal, right foot pedal , split break upper right, thanks thou..
   / What is user UNFRIENDLY on your tractor? #16
The notorious grease fittings on my JD 2210!
   / What is user UNFRIENDLY on your tractor? #17
On both the front and rear tires. The six bolts that attach the centers to the outer rim are reversed. Its a grade 8 carriage bolt with the nut on the inside of the rim. I've never taken the wheel apart - separated the center from the outer rim - but when I do my annual - "check the torque on the wheel nuts" - its a true PITA to check these six on each wheel.
   / What is user UNFRIENDLY on your tractor? #18
Don't know if this fits, but on my Kubota the split breaks and the floor peddle are on the same side, my right foot can't be in two places at the same time. How is this supposed to work ?
It's a B2920..
It's not just kubota, My Mahindra Max 25 is the same and so are the Kioti's. Dumbest thing I ever saw. Mine has an accelerator lock so I guess you could lock it full forward and then use the brakes?? Havent tried it...too much to run into around my place...lol
   / What is user UNFRIENDLY on your tractor? #19
Diff lock is on the right side, along with throttle pedal, hate using the hand throttle.
No clock, no boost gauge, no tool box, no cup holder, no right handle, no right step.
   / What is user UNFRIENDLY on your tractor? #20
Why ? It is there so you can use it !! I run my L3010 in the woods in snow and ice and need to use the steering brakes and diff lock often when skidding logs. I have a manual transmission not HST. I set the hand throttle to a speed that is comfortable for any where on the entire route and at a good power point. While driving thru easy sections I use the foot throttle for more speed and over ride the slower hand throttle setting. When I need the dif lock or steering brakes my speed drops to the hand throttle setting while the right foot is busy with those other pedals. Maybe you would like doing it that way better.
I wish I had a clock also. Would be very handy.
gg
UNUSED FUTURE WALK BEHIND POWER TROWELL (A52706)
UNUSED FUTURE WALK...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
2022 New Holland C332 (A53317)
2022 New Holland...
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
Horse Statue (A55853)
2018 Ford F-550 Versalift Stamm ATR45N 40ft Bucket Truck (A55852)
2018 Ford F-550...
