Ford 2120 brakes
/ Ford 2120 brakes #1
mildot1
Ford 2120
Sorry to come on as a new member and my first post is asking for help.
Have a 97 2120 that the brakes have left town on.
How hard a job is it?
Are any of the after market disc's worth using?
I will probably drain all fluid and replace filters since I'm sure there are pad parts floating in there.
Any help would be appreciated.
Brad
/ Ford 2120 brakes #2
Brad
I replaced the brakes on my Ford 2120 a couple of years ago and it is very easy. The 1720. 1920 and 2120 all use the same part nos. for the discs but they just use more discs as the tractors get bigger The main difficulty is that you have to drain all of the transmission oil. The New Holland friction discs are expensive however they are available in the aftermarket. The intermediate steel discs are only available from New Holland but aren’t too expensive. You will defiantly need to replace both friction and intermediate discs as on my tractor they were both damaged. I would suggest that you soak the new friction discs in transmission oil for a few hours before installation as I did not and my brakes groan somewhat when I apply them but I am not sure that this is the reason.
If you want to see a picture of the brake actuator assembly for your tractor, there is one on ebay. Put in the words “Ford/New Holland Tractor 1920 BRAKE ASSEMBLY RIGHT HAND “ and you can see it. The actuator on the 1920 and 2120 have the same design. I was worried the actuator would fly apart but it won’t
Use a New Holland Oil filter as I tried an aftermarket and it did not allow enough flow and the hydraulics were slow until I changed it to the NH filter. Also you will need to order a new cover gasket.
Stout Utility Grapple XHD76 (A66285)
Stout Utility...
JOHN DEERE 1705 - 6R30" VACUUM PLANTER (A64277)
JOHN DEERE 1705 -...
2006 STERLING AT9500 6X4 T/A 14FT DUMP TRUCK (A59914)
2006 STERLING...
2006 JCB 506C HIGH LIFT TELEHANDLER (A62613)
2006 JCB 506C HIGH...
1998 Volvo VNL64T Sleeper Truck (A62679)
1998 Volvo VNL64T...
Bulk Lot - (3) Sticks HDPE Pipe - 24in x 40ft - Selling as One Lot (A63689)
Bulk Lot - (3)...
