Did I Dodge a Bullet?
/ Did I Dodge a Bullet? #1
crashz
Elite Member
NH
Kubota L2501, JD LT150, DR Field Mower
Was bush-hogging this weekend with the L2501 for a few hours and hit a rock. A big, solid piece of NH granite. Due to the location I could not lift (my first response) the cutter as the front of the tractor inclining sharply as I went forward and therefore keeping it at the cutting height. By the time I realized that lift was no good, I was out of it. But it was 5-7 seconds of severe banging and horrible sounds /vibrations. I stopped the machine, let it idle down and realized the cutter stopped spinning. Was idling and panicked that the PTO was busted. But looked down and saw the PTO lever was in the off position. Hmmmmm...
Now, this cutter has a slip clutch that I admittedly have not adjusted. I think its rusted solid. Before its used again, I will fix this or add a new one.
I left the PTO off for a minute, checked the blades (a little rounder than before, but no major harm), got back on and fired up the cutter. All is well. No strange noises. Finished the job, went home and cut my lawn with the finish mower. Turned the PTO on and off as needed, maybe 6 or more times since. No problems.
Was this the ultimate piece of good luck? God's hand? Fantastic Japanese engineering? All three? I know I didn't shut it off.
Any thoughts or explanation on this? Anything I should check or maintain (other than fix that slip clutch!)? I just did the 50 hr service, but a full fluid change was not required. Maybe I should change it out? I'm thinking my local church could use an extra donation...
/ Did I Dodge a Bullet? #2
Unusual. Must have shocked it hard enough to dislodge the controls.
Definitely work on the slip clutch.
/ Did I Dodge a Bullet? #3
You need to loosen & clean a slip clutch annually at a minimum.
When I did the maintnance on my tiller last year it was an eye opener. I loosened up all the bolts so they were flopping around loose & it wasn't loose at all. I jammed a 2x4 into the tiller tines & fired it up at an idle. There was a nice loud bang. The tiller cut over half way through the 2x4 before the clutch let loose.
Nothing but rust & junk glued it together enough to cut well over half way through a 2x4. Add that to the properly tightened bolts & it wouldnt ever slip. Make sure you loosen it up & run it a bit while slipping to polish off any rust & pitting.
/ Did I Dodge a Bullet? #4
I like your slip clutch method Fallon...........not very complicated and does a good job from what I can envision.
/ Did I Dodge a Bullet? #5
You were lucky for sure;could have been real expensive.Now purchase a new slip clutch and service every year;about a 15 minute job.On mine ;I loosen and back into some brush to stop the blades,let it spin for a minute and retighten.
On my tiller;the same but just lower to engage the tines.
/ Did I Dodge a Bullet? #6
That sounds like it could be hard on the PTO. I wouldn't try it with My L3400 HST as the PTO's on them seem to be fragile anyway. It is a good way to break it loose though.
/ Did I Dodge a Bullet? #7
Yeah, I wouldn't recommend any method that prevents the implement from turning. Put a load on it and if that doesn't work you might want to disassemble the clutch. They are amazingly simple to take apart.
/ Did I Dodge a Bullet? #8
With my Land Pride tiller, I just back off the bolts on the slip clutch the number of turns specified in the Owners Manual and with the tiller and tines firmly planted on the ground, then engage the PTO. Never failed to free the clutch every Spring.
/ Did I Dodge a Bullet? #9
I'm sure it wasnt great for the PTO on my tractor. I wasnt expecting it to be that stuck together though. The slip clutch isnt that hard to loosen & what not, other than its underneath bracing on my tiller. I already leave the back of my 3pt tower bracket off permenantly so I can get to the PTO shaft grease zerks & get to both sides of the nuts/bolts on the clutch without 4' long arms.
As a FYI, there is a 2nd less common slip clutch. I've got one on my 3pt trencher. It's more or less a bowl containing the plates. The 4 bolts on one end are for compressing the spring. You tighten the nuts down, it compresses the spring. Then when the pressure is off the retention plate you can bend the sides of the bowl near the outer rim so the plate & guts come out. Not nearly as easy to service. It tends to not be that big of a deal in practice as it's easy to gradually increase the load until things slip. My L4060 has more power than the clutch will transmit & I dont have rocks & roots. Trencher - Google Photos
/ Did I Dodge a Bullet? #10
I loosen the springs occasionally, let it slip some, and then retighten the springs. When I am tilling I will use a point and shoot thermometer to check the clutch temperatures under a high load and if it raises in temperature I know it is slipping and then go to do some regular tilling. If it cools down again I think I am good. Also, if you paint a line across the clutch pieces you can see if it has slipped.
/ Did I Dodge a Bullet? #11
Was bush-hogging ... with the L2501 for a few hours and hit a rock. A big, solid piece of NH granite.... But it was 5-7 seconds of severe banging and horrible sounds /vibrations.
Yes, in a sense you dodged a bullet but you are very likely to dodge a LOT of them in the future if you cut much.
First, it is the hog at risk more so than your tractor. OK, confession time. It was 18 years ago when I first began to cut pasture brush on a brand new JD4700 with an MX6 hog on the back. A hilly WV farm with a moderate abundance of rocks. I had cut in prior years with smaller hogs and old tractors not up to the task. I've been trying to pick up those rocks and get them off the mowable areas since I was 8 or 9 with my grandfather and I am 75 now. It was after not more than 4 or 5 hrs of use that I hit a head-sized sandstone rock and shattered it to pieces with the remains clunking around under the hog for several seconds as I hurriedly raised the hog. Scared the beehaysus out of me ! During the last 18 years I have switched to a MF2660 pulling a Bush Hog brand model 297 7ft hog. Every cutting season I will hit 4 or 5 big rocks that I somehow did not see, though I try hard to avoid them. I do NOT abuse my machines but rock hazzards are often impossible to avoid. The more you cut a piece of land the more you get rid of the worst.
I have been just amazed at how hard the steel is in hog blades! Secondly, both the MX6 and the BH 297 stood up beyond what I thought was possible over the years. Both had slip clutches which are good but don't depend on them for a whole lot. Your slip clutch is adjusted about right if you get some squeal when you engage the pto but do not detect slippage while cutting even in heavy brush. The suggestion to loosen and re-tighten about once a year is a good one. While a slip clutch may look "rusted solid" that is very unlikely at the actual friction surfaces. Many suggest measuring the adjustment bolt /spring length between the contact surfaces and maintaining that tightness over time. Cut and try to get it right to start with. The springs will lose tension but it takes years.
So my bottom line advice is: Do not be overly alarmed by some nerve jarring awful sounding clashes back there so long as they are fairly rare. Obviously avoid all those clashes that you can. Maintain your stuff well and inspect for nicked blades and other issues frequently.
Thanks guys! Both relieved and motivated to adjust the slip clutch. The clutch is one that I haven't seen before as it doesn't have springs, but one huge center nut that I think gets tightened to adjust pressure.
/ Did I Dodge a Bullet? #13
Yep, there will be a "cupped" spring washer between the nut and the clutch plates. Tighten the nut and apply even and constant pressure against the disc pack. Very common and durable setup.
/ Did I Dodge a Bullet? #14
Bingo.
Few people even adjust a slip clutch appropriately for the HP of the tractor, and almost no one loosens a slip clutch annually to prevent corrosion lock.
This is why a shear bolt is better protection for most folks than is a slip clutch.
SDT
/ Did I Dodge a Bullet? #15
Bingo.
SDT
True, people do not adjust or pay attention to slip clutches very often. That is a good reason to have them, not a reason to avoid them. That is not a good reason to go without one and use the mechanically crude, yet cheap, solution of a shear bolt/pin. Slip clutches rarely ever cause lost time or problems. Shear bolts are simply a pain in the tusch. Most drivelines are using so much plastic to protect us from ourselves that getting to the shear pin to drive the broken part out and replace it becomes a lost-time issue and waste of time. Shear pins and related holes are sensitive to near perfect fit and chronic breakage issues including out of round holes,selection of material in the shear pin, and other wonderful wastes of time. A slip clutch is an excellent investment if your time is worth anything and you want to protect your equipment without a lot of nuisance.
Of course there are other opinions but that is mine.
/ Did I Dodge a Bullet? #16
Both good discussion.
The precise wording of SDT's is the most logical.
A slip clutch requires at a minimum annual investment of time. My 6ft shear bolt cutter has required no maintenance in 7 years of use with no broken bolt.
With that said, I prefer clutches on my larger cutter.
/ Did I Dodge a Bullet? #17
I was pissed when I found no clutch on my rotary cutter that was suppose to have one when I dug around under the guards to do the annual maintnance. 0 maintnance on it other than greasing when I sold it 3 years later. So really it ended up being better with a pin I never sheered.
/ Did I Dodge a Bullet? #18
It varies so much with the individual's situation and what/where he mows.
SDT, Overszd and Fallon are right and have good logic depending on which of the many situations you are in. I use a 4ft clunker JD hog in one location pulled by a B2150. I use a 5ft near-new Bush Hog brand using a different B2150 in another location with drastically different topography, humps, bumps and obstacles. All this monthly. Both those are shear-pin hogs. I've had to replace pins on the 4ft JD 3 times over 5 years and the 5ft unit 3 times in 2 years. A problem is that it is so easy to accidentally run over a hump or pile of something in a few seconds of "not paying close enough attention" and can't hit the shutoff fast enough. With these smaller shear pin hogs, that means downtime and frustration fooling with shear pin replacements. As overszd says, I would never put up with shear pins on my larger hog (7ft Bush Hog 297) also used monthly. The slip clutch on it has been very effective and totally trouble-free. Never 1 minute downtime for that.
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
(2) 380/85R28 TIRES W/10 LUG RIMS (A62130)
(2) 380/85R28...
New/Unused Landhonor 8ft X 10ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
2007 MACK CHN613 6X4 T/A DAY CAB TRUCK TRACTOR (A59909)
2007 MACK CHN613...
Vision 250/50R15 77D Golf Cart Tires (A61166)
Vision 250/50R15...
UNUSED JCT 72" HYD TILLER (A62131)
UNUSED JCT 72" HYD...
