crashz
Elite Member
Was bush-hogging this weekend with the L2501 for a few hours and hit a rock. A big, solid piece of NH granite. Due to the location I could not lift (my first response) the cutter as the front of the tractor inclining sharply as I went forward and therefore keeping it at the cutting height. By the time I realized that lift was no good, I was out of it. But it was 5-7 seconds of severe banging and horrible sounds /vibrations. I stopped the machine, let it idle down and realized the cutter stopped spinning. Was idling and panicked that the PTO was busted. But looked down and saw the PTO lever was in the off position. Hmmmmm...
Now, this cutter has a slip clutch that I admittedly have not adjusted. I think its rusted solid. Before its used again, I will fix this or add a new one.
I left the PTO off for a minute, checked the blades (a little rounder than before, but no major harm), got back on and fired up the cutter. All is well. No strange noises. Finished the job, went home and cut my lawn with the finish mower. Turned the PTO on and off as needed, maybe 6 or more times since. No problems.
Was this the ultimate piece of good luck? God's hand? Fantastic Japanese engineering? All three? I know I didn't shut it off.
Any thoughts or explanation on this? Anything I should check or maintain (other than fix that slip clutch!)? I just did the 50 hr service, but a full fluid change was not required. Maybe I should change it out? I'm thinking my local church could use an extra donation...
