AGCO ST35X
/ AGCO ST35X #1
dnw64
SE Vermont, South Jersey
Kubota B3030 Cab
I posted this in the Massey forum thinking that was the place to put it. But after getting almost no response I decided I'd try here.
I'm finding my GC2300 a bit small for our new property. That, in combination with discovering I should have bought a tractor with a loader, is prompting me to look for a "new" tractor.
Current expected purposes:
*Blow snow (primary use)
*Mow/cut about 8 acres of field (primary use)
Till garden
Loader to move stuff
Maintain existing logging roads for recreational purposes
Possible backhoe addition
I have been looking for a tractor in the 35-40HP range and 3000# or so. I would prefer a hydrostatic transmission, primarily because of blowing snow - I have found that it makes it very easy to pick exactly the right speed and adjust as conditions change.
I have found the subject tractor that has just about everything I want:
Key things it has are:
Cab (required!)
Front snowblower, 63" (required!)
Loader (required)
Synchro shuttle tranny
7xx hours
My thought is that this tractor has roughly 15% more PTO HP per snowblower width, so while I may not be able to always "max" the usable HP, it has adequate power that I should be able to maintain a reasonable speed and still blow the snow.
Asking price is $16k
It's for sale by the same guy I bought my GC2300 from, so I know the guy is fairly reputable (not that you can make a generalization from one transaction, but I was happy with the sale).
Link to listing:
https://www.ackequip.net/inventory/...e/21514035/2004-agco-st35x?dlr=1&pcid=3600679
Any feedback on the tractor based on my needs/desires, as well as the price? Comments on anything you see in the pics on the listing?
BTW, I am assuming this tractor is just a re-badged MF? If so, what is the equivalent model? I've been looking and just can't figure it out.
/ AGCO ST35X #3
Till garden
Cab (required!)
Loader (required)
7xx hours
Link to listing:
Appears to be the same as a mf 1433v or similar, but with a cab. I don't see a number of hours listed on the posting. Here in South Carolina, that would be a $10,000 tractor without the cab.
/ AGCO ST35X
It does seem to be very similar to the M-F 1433. TractorData has some differences but I'm not sure how accurate that site is.
786 hours.
Without the cab... and snowblower? Kind of assuming that tractor mounted snowblowers are a rarity in SC. New, an aftermarket cab and front mount snowblower are a good $12k.
/ AGCO ST35X #5
Just tractor and loader would be around $10,000 here. 786 hours is nothing on a shuttle transmission. I'd say it is worth the asking price if it comes with all those goodies you mentioned.
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
Water Pump with Engine (A65640)
Water Pump with...
2022 EZ-GO ELITE...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63689)
2006 Cadillac...
Landhonor ATS-RT12R Mini Excavator (A66285)
Landhonor...
