Disc Harrow No bearings
/ No bearings #1
Texomahog
Member
Ada, Oklahoma
Mahindra 2538
Does anyone know if any company still makes a disc without bearings?
/ No bearings #2
Are you referring to the type of bearings with small balls or rollers in them? If so my land pride disc does not have them. I suspect many do not. It just looks like they do.
P.S. Well it seems I made two mistakes. First one is that I have a woods brand and for my second mistake it does have sealed bearings.
Used to use a friends old disc and I had to do some work on it and I guess that the one I am remembering since I was surprised by assuming all would have bearings. No idea what brand it was.
/ No bearings #4
I have a light duty Land Pride DH1048 - it has sealed ball bearings. Redlands Okie - check you owners manual - I'll bet you have sealed ball bearing also.
/ No bearings
I have had a 4 ft. disc for several years that has no bearings what so ever. I bought it from a dealer in OKC who told me he recommended it because I only use it twice a year for deer plots. After about three hours of use, you just pump more grease in it. The dealer recommended it because he said only using it twice a year I would have problems with the bearings as it is stored in a large open shed and does get a lot of moisture. I am pretty sure it is a Chinese made implement, but, it has worked great and was dirt cheap. I am about to bet a much bigger tractor and will need a larger disc. I looked on line and could not find anything without bearings. By the way, I am buying a Mahindra and their discs have sealed bearings. Would that be okay stored in a wet environment as I can get it at a much reduced cost when buying the tractor.
Than you guys!
/ No bearings
Rick, excuse my ignorance. I assume what I meant was ball bearings, am I correct?
/ No bearings #8
Than you guys!
I have a 6 ft. that's a good 25 plus years old that must be like your 4 ft . I use to load it up with cement blocks and haul it behind my m5700 until I got the 2650 . It has no roller bearings either just some grease fittings I grease once a year . It has had some use as we had market gardens at one time . I'm surprised it is still going strong seeing as this has what is called friction bearings and takes a lot of grease each time I do grease it .
/ No bearings #10
Don’t think you’ll find a larger new disc with the cast bearings. I have a older Massey disc with sealed bearings, that has set out for the last 20 years, used to disc 4-5 acres a year or so and have not had any bearing failure.
/ No bearings
Thanks Country. I actually found the company that made mine in Alabama and they still make a disc with cast iron bearings. A five footer was about $800. I can probably get a Mahindra with sealed bearings close to that with the discount they offer when buying a new tractor. I may take your advice and go that rout. l use at least two tubes of grease every two to three hours of use and I do about three acres twice a year going over the plots at least twice. That's a lot of grease plus a one mile trip on the tractor back to the barn to re-grease the critter.
2000 Ford Windstar Van (A61574)
2000 Ford Windstar...
Kubota L175 Tractor (A62613)
Kubota L175...
2015 MCLENDON HITCH TRAILER (A64278)
2015 MCLENDON...
2014 KAWASAKI KAF400B (A66091)
2014 KAWASAKI...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
Wooden Glider Chair (A64557)
Wooden Glider...
