clutch going?
/ clutch going? #1
pdmholmes
cowichan bay, b.c.
john deere
Hi, I have to have my foot off the clutch pedal before it engages on my ford 5200. Have been using it on my new Holland 644 baler and I wonder if that is too much work for it? is it expensive to fix the clutch?
/ clutch going? #2
Mechanical clutches have some adjustment as the friction surface wears. If the clutch cannot be adjusted to give the proper pedal travel, it may be worn out.
I guess I should have asked; Does the clutch operate fine in other conditions? Is it just the baler that causes this?
/ clutch going?
I just noticed it baling yesterday and its still attached to the baler for one more day tomorrow. hopefully it will last.
I did notice the clutch pedal needed to be 3/4 or more released before engaging the last few weeks. is there some way to adjust something on the pedal that could help for tomorrow?
/ clutch going? #4
Clutchpedalfreetravel is very importend ! Adj to 11/2 inch
/ clutch going? #6
If the clutch disengages when you push the pedal down, and pulls a load without slipping, I agree that the clutch linkage is out of adjustment. Checking and adjusting clutch pedal travel is part of routine maintenance. It should be checked at every oil change.
/ clutch going? #7
thanks ill have a look for something to adjust. not sure where to look but it must be close to the pedal I am thinking.
The rod to adjust is under the floor board on the left side of the tractor. It's connected to the pedal by a clevis that can be adjusted. It has a jamb nut on it to keep it from vibrating and coming out of adjustment.
/ clutch going?
thanks for help
I adjusted rod under left foot about 1/2 inch or bit more. it then seemed to engage just before releasing pedal. managed to get 10ish bales done before the tractor would conk out when engaging pto, so I unhooked. it still seems to drive without being hooked up to baler so i will see if I can use the front bucket to load some bales on the trailer to get them out of the field.
hoping a neighbor can finish off for me today.
2024 Bobcat T650 (A64126)
2024 Bobcat T650...
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A61568)
2019 Ford F-350...
IRGC40 High End Mini Golf Cart (A64127)
IRGC40 High End...
Dueling Tree (A65640)
2022 CATERPILLAR D3 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
2008 PROGRESSIVE 20' X 7' BUMPER PULL TRAILER (A65643)
2008 PROGRESSIVE...
