L2850 won't start, v1702 engine
   / L2850 won't start, v1702 engine #11
Just check & adjust the vales before condemning the engine..
incorrectly adjust valves will have a big factor in compression readings.
I didn't do a proper check, but I had the valve cover off and all springs that weren't depressed were loose including the 2 on the lowest compression cylinder.
Are valve seats a common problem on these?
   / L2850 won't start, v1702 engine #13
Not to my knowledge.. BUT cracked heads due to over heating.. YES.
They WILL NOT tolerate any heat..
Would a cracked head push exhaust out the intake?
   / L2850 won't start, v1702 engine #15
anything is possible..
Take a dollar bill & hold it over the muffler exhaust stack on a running engine, at idle.
IF the bill sucks in & blows out, you have valve/head problems..
IF it just blows away from the stack, your back at square 1..
but my money is on sucking back in..{valves}
If only it ran! Like the king said, off with yer head!
Head is off, I poured some leftover mmo in the suspect cylinder and sure enough it starts seeping past the valve.
Is there any good way to identify cracks without taking it to a machine shop? They are spendy here.
Perhaps I should ask where they cracking so I can look there
   / L2850 won't start, v1702 engine #19
I think I would take it to a machine shop and have them magnaflux it. I wonder if your valves just needed adjusting? Look around the valve and seats.
I ordered a valve spring tool so I'll remove them when I get a chance, being a top exhaust I wondered if some water got in there and pitted the valves? I'll know soon.
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
Water Pump (A57454)
Water Pump (A57454)
yellow ball Trailer (A56859)
yellow ball...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
CENTRAL PNEUMATIC SAND BLAST POT (A52708)
CENTRAL PNEUMATIC...
New/Unused Quick Coupler (A57454)
New/Unused Quick...
