choosing between a used with no DPF and newer with DPF
   / choosing between a used with no DPF and newer with DPF #61
Sounds like you have a nice tractor that is set up well. For break in, I would minimize idling and very light work. Keep a good load on the engine as much as possible to seat the rings. Congratulations.
   / choosing between a used with no DPF and newer with DPF #62
It sounds like a nice tractor, and should give you many years of hard work. Used implements can be hard to find and Land Pride is one of the best out there .
However, I need to remind you; without pics, it never happened.
PS; your neighbors aren't the only ones who are envious. ;) :thumbsup:
Not sure if I got this pic right or not...but here she is!
Almost too pretty to use!
   / choosing between a used with no DPF and newer with DPF #67
Good job, and congratulations!
You'll have questions once you start using that beautiful machine...just remember, there's a lot of collective knowledge on this site so just ask away!
And as far as the original question about DPF, I had the same concerns when I got my M7060. But as long as you keep the rpms up - especially if the light comes on says it needs to regenerate - then the system will cycle through the process without problem and without any input needed on your part.
Bucket Truck (A59230)
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
2005 Chevrolet Impala Sedan (A56859)
2005 Chevrolet...
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
