Compost Tumbler
/ Compost Tumbler #1
goeduck
Super Star Member
Kitsap, WA
Kubota, Massey, Iseki
Anyone have opinions on compost tumblers? I am looking at something specifically for kitchen vegetable scraps, coffee grounds, etc. for compost to be used in potted plants and raised gardens. I think that I would want a reasonably heavy duty, at least two sided tumbler. While I fill the one side the other is finishing off.
I have started burning my larger debris and am wanting to create lower volume, higher quality compost for tomatoes, herbs, seedling trees, flowers, etc.
/ Compost Tumbler #2
Well, we had two when we lived more urban. One of the big green Compost Tumbler brand and one Mantis twin which was the two sided one. We still have the Mantis. I built a smaller tumbler for my MIL and learned that the larger the better as far as building good compost. It isn't a joy to crank these things around. At least I didn't look forward to it. We put them both on pavers to keep the frames healthy. For what you are doing, it could be a good tool. They do compost well and I'm sure keep rodents from actually feasting on the goods, though juices drip out. The best tool since already been sliced bread, probably not.
/ Compost Tumbler #3
I got a free plastic barrel that sits on a plastic base with four rollers. I turn it every now and then, which there is no easy way to do, but the contents are just a solid block. I have thought of ways to turn it possibly electrically, but I just have too many projects and it's not a priority.
/ Compost Tumbler #4
Vermicomposting will turn out higher quality since you don't need a great volume. Here's what I do. Torn up cardboard,shredded office paper,grass clippings and chicken litter go's into a bin with opening on side at bottom where I can use square point shovel to remove oldest material and throw it on top or if material is broken down pretty good, into a second bin with same opening to flip material or transfer it to a tumbler. My tumbler lay's on the ground where I occasionally give it a roll with my foot. Before material is completely broken down,it's moved to a plastic box similar to a 15 gallon tote except has lids on top and bottom. Worms live in the compost and fed kitchen scraps and coffee/tea grinds. Surplus scraps and grinds go to bins and tumbler. When material is totally broken down,top is left open and covered with screen to keep birds out. Within an hour,sunlight drive's worms from near surface and material can be skimmed off and into an identical box and kept moist for a few days. Eggs that were transferred with material will hatch, the open lid-skimming is repeated and material is used or stored for future use. As layers of material are removed over 1 to a few days,worms retreat, form a ball and can be harvested. I sell some,gift some and put some in bins and tumbler. Other than keeping everything moist,I spend very little time managing compost. Winters are mild in Tx but if worms aren't indoors during a rare hard freeze,when weather warm's,eggs hatch and population reestablishes. Decayed material is often removed from bins to be used as mulch.
/ Compost Tumbler #5
I put our kitchen compost into an old (1970ish) plastic garbage can that we had in NJ. Start off with one urinal of urine in the bottom of my little plastic bin I keep in the kitchen in the basement. Empty bags of compost from the main kitchen into it and either pee into it and/or pour more urinal urine into the garbage can. Throw in some "brown" material from my main compost pile beside it. When the garbage can is full, it's pretty much black compost that I then put into the middle of my main compost pile by lifting it and dumping it with my FEL. First scrape off the top of the main compost pile and then remix it all when the kitchen compost gets dumped.
Never felt the need for one of those turning machines. Think they work pretty well though. Don't turn my garbage can, and it turns pretty much into black compost by the time it's full. Just need to do the lasagne layering.
Ralph
/ Compost Tumbler #6
After reading Ralph's post I realized I might have left a key element out of my composting method. My old dog routinely lift's a leg on my bins. That may also account for why rodents don't mess with my bins.
/ Compost Tumbler #7
They work great! It's a smaller volume of compost for sure, but I was really impressed with how fast everything composts compared with the big compost pile in the yard. Don't even think you need the two-sided. We have a large compost pile of yard waste also, but the barrel is way more convenient for dumping vegetable scraps, etc., from the kitchen, as you can put it outside near your kitchen door. Plus the critters can't get to it. I think it's great to have both (the "big pile" and the barrel).
And while we're on the subject, they make a nice little sink-side container you can dump your kitchen waste into (the charcoal filter prevents odor). Then just dump it in your barrel every few days or so.
Here are a few:
Compost Bin
/ Compost Tumbler
Here are a few:
Compost Bin
Do you have the rotating barrel style? If so, what brand?
/ Compost Tumbler #9
"they make a nice little sink-side container you can dump your kitchen waste into"
Frugal old farts like me call them two pound coffee cans.:D
/ Compost Tumbler
Equipped with the original plastic lid they would probably work pretty good :thumbsup:
/ Compost Tumbler #11
They really do. I often move them to the non-airconditioned mudroom where things tend to spoil and I don't notice the odor,,,,,,,,,,,,,until I remove lid to dump contents.:sneeze::ill::melodramatic:
/ Compost Tumbler #13
Trust me, the ones with the charcoal filters are soooo much better. No smell at all, even after several days.
/ Compost Tumbler
I am sure they are, I had one at one time but was not composting. Danged if I can find it now.
/ Compost Tumbler #15
Mom had one with a big molded in ring gear on the end outfitted with a hand crank that had a small pinion gear on it. She had it for several years and tried and tried to get it to make decent compost...never could. The stuff dried out so fast and it required a lot of attention.
She asked my father in law who has 10 green thumbs if he wanted it for free to which he gladly accepted the offer. He had it for several years and couldn't get it to make any decent compost. Sold it to some dreamer at a garage sale a couple years back. Now he has a pile out in the open in a 3 sided fenced in area that he turns with his Worksaver manure forks on the JD 3038e and has the most wonderful compost of all.
My advice: Compost tumblers are an expensive gadget for the "Pampered Chef" gardener and will soon end up in your garage sale pile....don't waste your money.
/ Compost Tumbler #16
The one we have is ComposTumbler. We have it in the sun, seems to help, and used a little compost starter. YMMV
/ Compost Tumbler #17
Right now, I just use a pile, and never turn it. I used to use bins made from pallets, but the bottom pallet half rotted away and the remaining chunks of nail-covered wood would catch on whatever implement I tried to use until I finally tore it all apart in frustration.
I wouldn't be opposed to some sort of bin setup again, more of the compost seemed to be usable and it was easier keeping out weeds...maybe one of these days I'll get some IBC totes, cut one side off, and try again.
