Testing your welds.
/ Testing your welds. #1
Shield Arc
Super Member
Port Orchard, WA.
John Deere, 4200
If you want to know how good your welds are? It is pretty easy to build a bender, to make sure your welds will hold.
/ Testing your welds. #2
But how do you know if your welds are sound enough that the jig will hold together?
/ Testing your welds. #5
I was kidding by the way
So, I know you’re kidding but the welds on the jig aren’t really stressed. I think you’d be hard pressed to do a bad enough job for it to fail.
/ Testing your welds. #6
Silly question. Are the pins in the bend box just cold rolled bar or hardened pins? I haven't given it a lot of thought but thought my JD2 tube bender might be able to do the same thing.
I used the rollers out of my compact bender. The only important thing, is make sure the ram that pushes on the coupons is 1 1/2-inch in diameter. Then I just used bolts to hold the rollers in place.
/ Testing your welds. #8
Looks like another future project to put on the list
/ Testing your welds. #9
I tried that on a couple of projects and it ruined them. Now I just loan it to my neighbor. If he can't break it,nothing can. :grumpy:
Scag Turf Tiger (A60463)
Scag Turf Tiger...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Toro z turn (A56859)
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
2019 KUBOTA SVL95-2S SKID STEER (A62129)
2019 KUBOTA...
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
