Mulching kit for BX 2680
/ Mulching kit for BX 2680 #21
So, you BX owners, are you taking the kit off at certain times of the year? Is it doing a good job all seasons, or should I expect it to leave windrows in heavy grass? $400 cuts into a bagger or Cyclone Rake, so I'm trying to avoid eating the cost twice.
/ Mulching kit for BX 2680 #22
Sounds like that would be a pain in the arse and get old quickly!
We will keep in on all mowing season, if we have to mow a little often, it is better than sweeping the grass. Sometimes this year we have mowed after 5 days. We mow 10 acres with the bx and f2690 mowers, both with mulching kits on them. I would not take them off, to big of a pain in the a@@@@@@.
/ Mulching kit for BX 2680 #24
Well, I already knew the answer, but thought I'd better check.
Now, to figure if I should spend the $400 plus freight and try it, or just go with the bagger/rake I'll need in fall anyway.
What will you need the bagger/rake for this fall. I just mulch my leaves. I used a sweeper in the past, bought one 3 or 4 years ago, it just takes up space now. Good luck on whichever way you go.
/ Mulching kit for BX 2680 #26
I have three large sycamores and silver maples. The leaves are either so massive or thick, I can't mulch. It just kills my grass in spring.
/ Mulching kit for BX 2680 #27
I like that mulching puts the cut/nutrients back down rather than hauling it away.
/ Mulching kit for BX 2680 #28
I haven't raked leaves in over 20 years. I have lots of trees also. Try the mulcher on the leaves and maybe do a couple passes in different directions. Maybe even mow them every couple weeks during the dropping season. Maybe mow with deck a bit higher and then come back later and drop the deck down and chop them again. The mulcher will chop them to fine particles if it is working right and your BX2660 will have plenty of power to do it. Just keep in mind your chopping/mulching and not mowing grass so may need to slow down a bit in heaviest concentrations.
That is what I do.
/ Mulching kit for BX 2680 #31
Well, now, I can't find favorable information on those who have added the mulching kit to the 60" MMM. One guys posts litter the internet with his issues, and he returned the kit. I may punt and try it. Just not sure yet.
/ Mulching kit for BX 2680 #32
We all appreciate Guinea Pigs! :laughing:
Robertm, Jt and myself both like the mulching kits on our bx's. His is a bx2370 and mine is a bx2680. Mine works great, Verry happy that I installed mulching kits on both the bx and f2690 kubotas. Wish I would of done it earlier. In my case I mow every 5 - 7 days depending on the weather. Later on in the year maybe 8-10 days. But whatever the time the yards look great, very little clipping on mower when done, no clippings on me(which is why I bought the one on the F).
/ Mulching kit for BX 2680 #36
Thanks 628pm. I think I'm going to give it a shot. I just don't know about mulching sycamore leaves. They are 12" in diameter and are usually still partially green when they fall. It's tough to mince them up. Maybe the mulch kit will do wonders, but I'm not sure. If the mulch kit is on, it kind of eliminates the possibility of running a bagger.
/ Mulching kit for BX 2680 #37
I have the BX2370-1 purchased last year with a dealer installed 60" deck with dealer installed mulching kit for which you seek input. I checked this morning to make sure mine was a 60". I'm totally satisfied with its cutting and distribution of grass clippings not on me and not in obvious rows. I can m ow close on either side and in random or no patterns and in any direction with equal distribution of grass cuttings. A satisfied user of the 60" with mulching kit reporting in.I also have sycamore trees along with many maples, hickory, polar and tulip poplar, walnut and apple, pecan, pear, peach and plum trees with totally satisfactory mulching of leaves.
/ Mulching kit for BX 2680 #38
Thank you Johnthomas. You have given me the additional push I need. I think I'm going to order it up Friday.
Thanks!
Just a fyi, I took my deck off to install the kit and clean the underneath of the deck. Be sure to have the deck completely clean underneath, when I installed the kit on the f2690 I didn't have the deck completely clean and the blades hit in one place, so had to take the kit off and clean it real good then install it again. Also if I remember right you will be drilling a few holes in your deck to accommodate the kit. But once done you will like it.
Good luck and report in after the install to see if you like it as good as JT and myself.
/ Mulching kit for BX 2680 #40
Thanks!
Yep I think JT can sell you anything. Just ask him how many tractors he has bought/sold! :laughing:
Hr:1033.8 (A61572)
Hr:1033.8 (A61572)
WOODS TS1680 - 14' ROTARY MOWER, 3PT (A64278)
WOODS TS1680 - 14'...
2015 Mercedes-Benz C300 Sedan (A64557)
2015 Mercedes-Benz...
(INOP) 36 BLADE DISC HARROW (A64278)
(INOP) 36 BLADE...
2017 Chevrolet Tahoe SUV (A64557)
2017 Chevrolet...
INTERNATIONAL 700 SERIES 6 BOTTOM PLOW (A64278)
INTERNATIONAL 700...
