What TYPE of grapple (not brand or salesteam) to go with?
   / What TYPE of grapple (not brand or salesteam) to go with? #1
handcuff
Member
Louisville'ish, KY
Hey guys,
I'm trading up to a new cabbed Kioti DK4210SE and take delivery in a couple of weeks. While waiting to take delivery, I am trying to decide on a root rake for my tractor and figured I'd ask for help. I've read all sorts of threads on the subject, but the more I read, the more questions I have (isn't that how it is *supposed* to work?) =)
So I came on to ask a few questions to help get some clarity:
First, let me give you my situation - I live in Kentucky, on a hobby-farm of 7.5 acres. I mow/tend ~5 acres of that and try to keep the remaining portion 'clean' - it is a wooded area. but I want it clear enough that I can walk through the woods without much obstruction. I use a lot of firewood over the winters, and often go cut the firewood from homes wherein trees have fallen. When I do this, i often take my tractor to load the firewood on my trailer before bringing it home. I also use the bucket and chains to 'grab' a bunch of thorn bushes that overgrow the fence line/edges of my property and try to rip them up (usually somewhat unsuccessfully).
My current tractor is a B2400 with an LA351 loader, so my new tractor will be a huge step up. I tell you this so you know what I've been working with for the last 4-5 years. That tractor is being sold as of tomorrow.
I am trying to decide on a few different things:
First - solid bottom or tines? - my dealer suggests going with a 'bucket' style bottom on it (not tines) so I could use the bucket also - this one. he says that this is what he has on his loader (for a skidsteer), and they work very well. I see most of the guys on here with tines, not buckets.
Second - short or long bottom? I see some guys that have the 'long' tines on the bottom, making a long "L" that functions a lot like a scoop with a lid. Then I see other guys that have very 'short' tines on the bottom, making it more like a clamshell.
Third - how wide? I was planning on going with a 48-60 inch, but my dealer suggested the 'same size as my normal daily bucket' (i.e. 72 inch) so i would be used to the footprint size of it. I think they 72 inch may be overkill, but figured I'd ask.
Finally - how 'hefty'? I believe I don't need a super heavy grapple for my size tractor and my needs. I don't want something wherein the tines will fold/bend, but I also don't need something over-engineered for a 75-150HP tractor that will weigh my tractor down without providing additional benefit. Lighter is always better, if everything else were equal...but everything else ISN'T equal, so often we trade weight for strength. How should I be thinking about this?
Then as an add-on question - DIY?: I was planning on having the dealer add the front remote and the trigger, but I hear guys on here doing it themselves. I am relatively non-mechanical - I CAN do mechanics, but I absolutely HATE it...like as in my-tractor-sat-for-six-months-because-I-didn't-want-to-change-the-alternator-and-alternators-are-easy level Hate. He is charging $800 to get the front remote installed and a trigger set up for my FEL stick/handle (I am fairly certain I want the trigger on the stick, but don't now how I'd add it there myself). It's a cabbed tractor, so I don't know if that adds to the complexity or not, but figured I'd toss it out there to get feedback...is this something that I do myself (and make my older teenage sons help with, so I have to not swear QUITE so much), or do I leave it to them? $800 seems in line with other dealer-installs, so I don't know how that compares to DIY.
Thanks in advance for any suggestions/advice.
-Scott
   / What TYPE of grapple (not brand or salesteam) to go with? #2
You have a loader with a 800 lb capacity. (assuming the LA351 is the capacity in kg like other Kubotas). That grapple the dealer's recommending looks heavy. Like it might weigh close to that. Not going to leave much for actually picking up stuff.
I got a grapple with long lower tines. I use it for picking up logs and firewood rounds and wanted the ability to stack more in the grapple. I also use it for piling cut brush and the longer tines can grab more. It's not that useful for pulling up my brush (because of the brush not the grapple) but I have been able to pull poison oak out of trees with it. The long lower tines on my 60" require greater turning clearance than the 67" bucket. I could have gone narrower to compensate but wanted the area for rounds.
The usual 3rd function kits retail for $850 or so. $800 installed would be a good deal. If you hate mechanical things pay someone to do it.
There's a difference between a diverter (one button and operate the joystick curl/dump) and a 3rd function (two button or/rocker switch). Make sure you get the one that works best for you.
Heya Eric,
Thanks for the feedback! You are correct that the Kubota's tractor has an ~800 lb capacity, but it's the one that I'm selling. The grapple would go on the new tractor (DX4210se) which should have a ~2,500lb+ capacity - but I agree with your concern about the weight...I'm trying to keep it light enough not to be an issue, even with the higher weight capacity. I'm changing my original post to clarify that it's going on the new tractor.
I didn't know the difference between the one-button and the two-button/rocker switch, so thanks. Which is more beneficial for the grapple? It seems like a rocker-switch would be, but I've got no experience in that world so I'm not sure.
   / What TYPE of grapple (not brand or salesteam) to go with? #4
Think OP was asking about Kioti's 4210 loader for a new Kioti not his Kubota?
Loader type: Kioti KL4010Z
Weight: 1098 lbs [498 kg]
Height (to pin): 98.4 inches [249 cm]
Clearance, dumped bucket: 72.4 inches [183 cm]
Dump reach: 12.6 inches [32 cm]
Dump angle: 55.5
Clearance, level bucket: 91.9 inches [233 cm]
Reach at ground: 65.4 inches [166 cm]
Rollback angle: 41.5
Breakout force (at pin): 2561 lbs [1161 kg]
Lift to full height (at pin): 1689 lbs [766 kg]
Bucket width: 55 inches [139 cm]
Sorry posted at same time
ps- I have a long tined L style grapple and am very happy with it, If grubbing roots was my #1 use then i would choose the short lower tine style
   / What TYPE of grapple (not brand or salesteam) to go with? #5
More than a little off topic, but you mention "clear enough that I can walk through the woods without much obstruction". Have you looked at getting a skid steer mounted woods muncher in to do the initial clean uot?
I haven't, but I'm looking at them now. I don't know if the price is in my budget (assuming the price I'm seeing on first-blush is indicative - about $8K). I like the idea though, and am continuing to look.
   / What TYPE of grapple (not brand or salesteam) to go with? #7
I bought this no name economy grapple new off Craigs list. I guess the guy bought it down in the US at a Richie Auction.
No grapple does all things.
Junky as it is, I have not managed to break or bend it. That surprised me.
I like the configuration, except it won't handle very large piles or single small logs well.
WITHOUT A DOUBT, I would go with a double lid if getting another. IT would just clamp irregular logs and material better.
I see little advantage in going too wide with a grapple. Narrow might actually be better.
My biggest beef with the grapple is that often stuff needs to be removed from among trees. Not a problem for brush, but for long trees. I would almost consider a rotating type claw and pull stuff out skidder style.
   / What TYPE of grapple (not brand or salesteam) to go with? #8
My opinions only:
1) A grapple on a bucket is useless. Nothing I have ever wanted to grapple fits in a bucket, and dirt doesn't need a grapple lid.
2) For brush or digging up roots, get a root rake. For firewood and trees get a L bottom grapple for the capacity.
3) Wider is not better. No way you want the same width as your bucket.
4) Get a grapple with greasable bushings.
5) $800 for the 3rd function installed is very good. At your level of skill and likely usage "true 3rd function" vs "diverter" doesn't matter. I only do one function at a time anyway.
Good luck! :)
   / What TYPE of grapple (not brand or salesteam) to go with? #9
Hope the OP doesn't mind if I piggyback on this discussion.
What are peoples opinions on root grapple vs rock grapple. I know the narrower spacing on the rock grapple adds weight but given the capacity to use it would that make a better tool for cleaning up wooded areas?
   / What TYPE of grapple (not brand or salesteam) to go with? #10
Keep looking. I got a quote on 3 acres of very hilly rock strewn overgrown woods. Painting a picture? It was rough! Total was $800.
3650 (A47477)
3650 (A47477)
Unverferth 9250 Auger Wagon (A59814)
Unverferth 9250...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
Case 930 Tractor (A59814)
Case 930 Tractor...
