Weed Killer?
/ Weed Killer? #21
Yes, perhaps a little more detail as to what you want to kill, and why? Do you want to kill an area to plant a garden (ground sterilization like pramitol or barrier are not a good idea).
And where you live would be a vital piece of info too.
Just how much do you want to spend?
My personal experience, spray cheap and spray often. I have tried many of the products that claim to prevent growth for a year. They just DONT WORK. These ground sterilizer's I have tried in my shop driveway, and in the driveway and patio areas of my apartments. They show quicker results than roundup....sure. But dont seem to ever last any longer than roundup alone, And I find myself still having to re-spray once every month or 6-weeks.
Pramitol costs $60 per gallon or $100 for 2.5 gallons. And you are supposed to spray it at a rate of ~5 gallons per acre. so its not real concentrated stuff. $200 per acre is pricy
The barrier stuff is $40 per gallon....and a gallon only does 7200 sq ft. So about 6 gallons per acre.....which makes it $240 per acre for the stuff.
Sure, if you only needed to mix a backpak sprayer and do a fence line or driveway it you wont need several gallons of the stuff, but again, I find it to work no better than roundup/24d mix.
I buy buccaneer 50% glyphosate for ~$50 per 2.5 gallons
I buy nufarm weedmaster 24d for about the same $50 per 2.5 gallons.
I mix 2 oz per gallon of each for hand spray, or one quart of each for per acre of tank sprayer. That puts me spending $10 per acre using BOTH 24d and roundup. A WHOLE lot cheaper and just as effective as anything else I have found.
/ Weed Killer? #22
IIRC "chlorine" is a gas. Could somebody be more specific....e.g. Clorox.....sodium hypochlorite???
yeah, Clorox=sodium hypochlorite which gives off Chlorine.. Pool Shock is stronger, and what I use.. the Chlorine dissipates quickly in the soil.. ever drain a swimming pool?. same thing but with a weaker concentration..
/ Weed Killer? #23
Please do not use chlorine as a weed killer. That is not what it is intended for. Neither is diesel or kerosene.
There are things that are much more effective and safer and LEGAL to use as weed killers.
/ Weed Killer? #24
Pouring boiling water on grass and weeds also works, very environmentally friendly too, but certainly is not cost effective.
/ Weed Killer? #25
I suggested kerosene merely because it's no worse of an alternative than what the OP is asking for. In hindsight I should have suggested asphalt. I'm not big on chemicals, they are just one tool in the toolbox and need to be used responsibly. Given the context of his question, I hope that he hires a professional.
/ Weed Killer? #26
Can't say it any better than this.
/ Weed Killer? #27
that's why I suggested sodium hypochlorite, many thousands of people have used that as a weed killer, and is much safer than Chlorine, which is a gas..
/ Weed Killer? #29
Salt will work, but will wash away if you're in an area with a lot of precipitation.
I am looking at salt to take care of weeds along fences and a few other places. It was my impression that once it was allowed to soak in - with rain or watering - that the soil there would be barren for a very long time. I don't know if that is the case yet but am trying salt out for a few locations. Here is an article I looked at a while back when I was considering trying salt.
How to Kill Weeds With Rock Salt | Home Guides | SF Gate
/ Weed Killer? #30
pelleted salt, used in a water softener will last longest. the smaller you get in size, the shorter the time to dissolve, and wash away..
/ Weed Killer? #31
I bought the 50 lb bags of salt which are supposed to be for water softeners for about $8 a bag. Not sure it was pelleted, but very coarse chunks.
/ Weed Killer? #32
pelleted looks like a vitamin pill,(oblong shape) but 3X the size. less exposed area=lasts longer..
/ Weed Killer? #34
I know that when I make ice cream and dump out the ice with rock salt it kills whatever was there.
I have not tried bringing up saltwater from the beach to kill weeds. I know on one of my properties we have a low spot next to that beach that on a high tide combined with a north wind the mouth of the creek becomes somewhat of an estuary. Canadian thistles and many of the grasses will not grow there.
/ Weed Killer? #35
They use salt on the roads in winter to melt the ice. By spring the softwood trees near many roads and especially the interstate are all brown from the spray kicked up by vehicles. Some recover, while others just die.
A few years ago somebody on this site mentioned using salt to keep the weeds down in their asparagus. Apparently that crop is more resistant to salt than most plants.
/ Weed Killer? #36
the grass along the edges of the highways always seems to recover just fine too
John Deere Tractor Step (A65640)
John Deere Tractor...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A65563)
2007 International...
New 11'x19' Metal Garage Shed (A62679)
New 11'x19' Metal...
VERMEER FT100 MULCHER (A64277)
VERMEER FT100...
Skid Steer Deluxe Hitch Plate (A65640)
Skid Steer Deluxe...
