Radiators, thermodynamics & fluid-mechanics questions
/ Radiators, thermodynamics & fluid-mechanics questions #1
fitterski
Gold Member
Nouvelle, QC
1987 Cat-426, 1991 Deutz-Dx-6.05, 2019 Husqvarna 2xHP
Why would the radiator input hose from the engine pump be larger than the radiator output hose to the engine thermostat? For the Cummins 5.9 diesel the first is 2-1/4" and the second 1-3/4".
If I connect two ATV radiators in parallel the flow will of course 'favor' the path of least resistance. Will this be a more or less pro-rata differential or more than that? If one of the hose lengths is say 90% of the other will that draw more than a proportionally higher flow into that one?
Much more complex, how to calculate the radiator requirement for an engine like a Cummins 5.9 12-valve diesel that will operate at ambient temperatures of 0c and less at 40% power on average? The heat generated will be less than the fuel BTU value because work also gets done and because the engine block also bleeds heat. I plan to use two 9.5"x15" core single row radiators with fans but If I can get away with it I'd rather use only one.
TIA
/ Radiators, thermodynamics & fluid-mechanics questions #2
I really dont think a single small ATV radiator, will keep a cummins running at 40% cool, even if it is below freezing.
I wouldnt even trust the job to just 2 ATV radiators.
The real question though.....why do you want such a large engine but only a 9.5x15 radiator??
I heard of diesel rams pulling a hood in front of the radiator in winter and that the thermostat on some hardly ever opened. I understand that in cruise most diesels don't work that hard, the only diesel I ever 'drove' before was a rabbit and I really had to load it to get any heat into the cabin but I don't have any other practical experience to lean on. The ambient BTW will be more like -10c to -20c.
The reason I want it to be no bigger than absolutely necessary is that it's going on a snow-blower, an extremely violent environment with space constraints and rads are extremely vulnerable.
/ Radiators, thermodynamics & fluid-mechanics questions #4
How big is the blower and how much snow?
Why a big engine if you don't need the power?
See my sig, or
Deutz powered JD Snow Blower from Hell 29 - YouTube
It isn't horsepower I need but torque, this engine will give me over 400 ft-lbs at 1600, at about half of the available power. Snow blower impellers work between 600 and 1000 rpm becoming less efficient above 700 and my 2.5:1 gearing geometry is about max due to space & weight constraints. The last engine gave me about 200 ft-lbs, this will double that.
/ Radiators, thermodynamics & fluid-mechanics questions #6
Heat exchangers are generally throttled on the outlet rather than the inlet.
This keeps the fluid in the heat exchanger at a higher pressure, therefore gases are less likely to come out of solution, therefore you get better heat transfer, less chance of gas-binding of the heat exchanger.
Source: I was a nuclear-trained submarine mechanic for twenty years.
I learn something every day!!! I always thought that the 7 or 15 psi came from gas pressure. The two ATV radiators offer about 1/3 the area of the diesel truck that the engine came from, that truck was probably engineered to haul a trailer uphill in 35c ambient so I 'think' I might be ok.
/ Radiators, thermodynamics & fluid-mechanics questions #8
You could mount heat exchangers somewhere on the blower like a snowmobile. The exchanger on my 900 Arctic Cat was surprisingly small for 150 HP.
/ Radiators, thermodynamics & fluid-mechanics questions #9
I assume that you are going to use metal tubing for the framework. If the two rads are somewhat short on cooling you could always run some coolant through part of the frame. Especially snow blowing as there is usually lots of cold air and snow blowing around. Good luck!
Edited to add that some irrigation pumping units in this area are cooled by heat ex changers. About 24 feet of 1.5 inch metal pipe inside an 8 inch pipe is plenty to cool an 80 hp natural gas pumping unit in the heat of summer
/ Radiators, thermodynamics & fluid-mechanics questions #10
Diesels run better at their rated temperature.
Fuel consumption and parts expansion are an issue if run too cold.
I would use the original radiator with proper thermostat and shutters on it.
Semi's can even have covers on the front that can be buttoned or unbuttoned for control.
Air flow is the key. I once drove a 1993 KW 20 miles back to the shop with a broken fan clutch in 84* weather.
The engine only ran about 10* warmer and I watched it very closely!
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
2016 Terex RL4 Towable Light Tower (A60352)
2016 Terex RL4...
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
2024 MAC TNAR39FR540 40FT T/A  FRAMELESS END DUMP TRAILER (A59906)
2024 MAC...
