DK35 Kioti lever question
/ DK35 Kioti lever question #1
double hunter
Gold Member
Ford 1715
Just acquired a DK35,,its a nice tractor, 4wd, loader, 604 hrs,,never have owned a Kioti,,seller did not have the owners manual,,there is a small lever under the 3 point lift handle, it is marked A and B position,,what does this control,,thanks in advance
/ DK35 Kioti lever question #2
that controls rear remote for a double acting cylinder.
/ DK35 Kioti lever question #5
No. The older model DK 35 didn't.
It would be nice. But just the standard 3 point lever by the seat.
The DK 35 SE model may have had the rear lever.
I was hoping thats what its for,,Im gonna add a hydraulic top link,it will not operate now,,its frozen up,,the previous owner inherited this from his father in law and he said it has never been moved,,Im liking this tractor so far,,thanks for the info
/ DK35 Kioti lever question #7
Keep spraying some penetrating oil on the valve. (Where the handle connects to the top of the valve)
After some time and a few applications it will hopefully break free.
Mine get to sticking sometimes and I have to hit them with penetrate fluid.
I need to spray the shaft for the 4 WD (the shaft going into the transmission the 4 WD handle hooks to) on occasion also for easy shifting.
the 4 wh dr lever is really stiff also,,been lubing it little and it is starting to get easier,,this tractor hasnt been used much in the last couple years and everything is stiff, the acelarator lever is stiff as a poker also, got this thing for so so I cant complain,,I pressure washed it and gave it good waxing and it really looks good.
/ DK35 Kioti lever question #9
It does, and it is as handy as a pocket on a shirt.
/ DK35 Kioti lever question #11
The RPM control lever can be stiff on these, but the solution is to remove the two clamshell like covers, screws are underneath and loosen up the bolts which allow the lever to move more easily, and lube up the connections with copper based anti-seize. I did it once and done for eternity.
/ DK35 Kioti lever question #12
Just don't get the throttle lever too loose. You want enough resistance to where it stays put where you set it.
Fellas Im liking this Kioti,,about got all the levers and controls loose enuff to use easily,,all but one,,the lever that controls the hydraulic outlet on the back just will not free up,,been putting penetrating oil around it but no luck so far
it freed up this morning,,been putting penetraing oil on it for a few days,,put a little pressure on the handle and a few reallly light taps with a hammer and there you go, got to find me a top link now
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
John Deere Rear Rim 38xWH14L (A64119)
John Deere Rear...
2016 Nissan Titan XD 4x4 Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
2025 SF60 60in Hydraulic Side Shift Forks Skid Steer Attachment (A61572)
2025 SF60 60in...
Bulk Lot - (10) 8in x 20ft Fat Lip Pump Hoses (A63689)
Bulk Lot - (10)...
2008 Big John 42' Log Trailer (A62613)
2008 Big John 42'...
