Air Comb for Air Filter?
/ Air Comb for Air Filter? #1
sdquick
Flagstaff, Arizona
Kubota L2501
Has anyone used one of these to blow out an air filter? I am thinking of getting or making one to simplify maintenance. Thoughts?
I searched and could not find any information on the forum. Please redirect me if this is on another thread. Thanks -Shawn
Amazon.com: Innovative Products of America 8:confused: Air Comb 12" Filter Cleaner: Automotive
/ Air Comb for Air Filter? #2
I have an Air Comb.. I utilize it to clean air filters,radiators & AC condensers. Mine is 24'' long.
Thanks, I assume it works well, is 12 inches the right size? (I know, that's what she said...)
/ Air Comb for Air Filter? #4
I made my own. Rather than tiny holes down the "nozzle" - I put a 90 degree bend at the end. Turn the air pressure down and blow the dust out from inside the filter.
/ Air Comb for Air Filter? #5
Amazon.com: Innovative Products of America 85 Air Comb 12" Filter Cleaner: Automotive
That should work as well as any of the others I have seen. I would get the 24" one in-case you need to stretch a little to reach the target. 12" seams short and 36" is too long for me. Remember, as oosik said, lower the preassure. 30 psi works for me.
I use the radiator genie with air and water wands.
Radiator Genie - Water & Air Cleaning Wands for High Efficiency Cooling Systems and Radiators - Blow Out / Wash Out Kit - - Amazon.com
/ Air Comb for Air Filter? #6
I have this same kit. Works great.
/ Air Comb for Air Filter? #7
The air comb seems like a good deal for air cleaners - although I have no idea if blowing out an air cleaner from the inside has any effect on how much grit gets in the engine. Instinctively it seems like it would help, but I've been wrong enough times to make me curious. How much change does it really make?
I wonder if anyone done any real testing that shows how using an air comb compares to a new air cleaner?
For that matter, one of my older tractors has a reusable oil bath air filter. How well does that work compared to replaceable dry elements? Anyone know of any studies?
rScotty
/ Air Comb for Air Filter? #8
Does it restrict the air flow so you don't damage the pleats of the filter? One would think that you would want good pressure and volume to clean a radiator and much less so for a filter.
/ Air Comb for Air Filter? #10
Nearly every (at least every one I've ever come across) OEM says not to blow out air filters (except pre filters). What i've been taught is that the filter effectiveness (i.e. how small a particle that can pass though is) increases as the filter becomes clogged, and that blowing out an air filter, only serves to either A: push the really fine stuff further into the filter and decrease efficiency (the vacuum loss across the filter) or B: damage the paper element and cause potential for particulates to move through. Large equipment OEM's generally recommend to only touch an air filter when the vacuum gauge indicates that it is becoming plugged. I personally use the daylight test - if you can't see daylight though the filter, its time to change the filter.
on a second note, I've never seen an air comb, but it looks like it could be very helpful for blowing crap out of other places like radiators and guard screens.
/ Air Comb for Air Filter? #11
Both my Kubota and Case IH manuals say to clean the air filters with compressed air, blowing from the inside out.
/ Air Comb for Air Filter? #12
I agree. At best I will blow down the pleats with low pressure once it had been tapped out. It send chills down my spine when I see someone grab an air nozzle with 160 pound of pressure behind it to blow through paper filter media. I dunno the proper use of what the OP is discussing. Just like it sends chills through my spine to see someone not want to spend 10$ on a spin on oil filter for a piece of equipment worth thousands. I'll try the orange can of death for $4.99 :confused3:
/ Air Comb for Air Filter? #13
I made my own air comb using 1/8" copper tubing that conveniently fits the ends of many air gun nozzles, in fact I have a few of different lengths.
Being copper the end can be bent to suit the application.
If you want flexibility you can even find small plastic tubing that can be adapted.
/ Air Comb for Air Filter? #14
rScotty
Well my anecdote on the former 7.3L 2003 PS used a Donaldson Air Filter.
It was built to be able to back flush with air and good for 75k - 80k miles (IIRC).
Black Stone lab reports normal readings for silicon was around 7 to 9 ppm.
What comes to mind is doing a UOA to monitor filter performance. But at our oil change rate may not know for a few years....ha...;)
One would thinking back flushing AF is beneficial in allowing rated air flow to perform.
Agree that low air pressure is the best.
A small pin hole in the AF will contribute to really polishing the cylinder walls.
First hand experience on a 93 F-150 5.0L with a K&N AF.
Notice it had no power and took near a mile (or so it seems) to pick up enough speed to pass a Yugo.
Upon inspection looked at AF and it had small openings between the fabric weaves. NEVER again!:mad:
If anyone has used these with a bazillion miles with perfect results great. YMMV, this is just my history/feedback.
I see threads going sideways easy. So let's not go there.
2008 Ford F-250 Pickup Truck (A61573)
2008 Ford F-250...
2019 MACK ANTHEM 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 MACK ANTHEM...
2011 ORTEQ ENERGY SERVICES MANIFOLD TRAILER (A63569)
2011 ORTEQ ENERGY...
2012 International Prostar (A63118)
2012 International...
2023 John Deere 8R 370 Tractor (A63109)
2023 John Deere 8R...
2015 John Deere 310SL 4x4 Extendahoe Loader Backhoe (A61572)
2015 John Deere...
