Satoh Beaver 370D Won't Start
/ Satoh Beaver 370D Won't Start #1
Llamafarm
Satoh Beaver 370 D
I replaced the starter on a Satoh Beaver 370D with one that has gear reduction. Does this affect the spinning of the engine ? Could this be the reason it won't start ?
Thanks
/ Satoh Beaver 370D Won't Start #2
The new starter will spin it faster.. no, that's not the reason it wont start.. if anything, it'll help.
/ Satoh Beaver 370D Won't Start #4
I think the service manual provides step-by-step directions and you can used these step for repair and replacement of starter.
/ Satoh Beaver 370D Won't Start #6
if you have sufficient spark, fuel, and compression, it WILL start, you are missing one of those..
/ Satoh Beaver 370D Won't Start #7
It's a diesel, so "spark" isn't technically an issue.... air might be a good thing to have too:thumbsup:
/ Satoh Beaver 370D Won't Start #8
+1. Lack of or reduced fuel delivery is the place I would start looking.
Thanks for replies, will try suggestions and go from there :)
/ Satoh Beaver 370D Won't Start #11
Glow plugs...... most older engines need them even on warmer days.
Dave M7040
I second that as I own a Mitsu, while in decent condition and maintained it still wants glow plug heat in warm weather. (in winter it wants 2 cycles even with plugged in block heater). Otherwise a great tractor.
(16) Kinze 3000 Precision Plant Corn Meters (A65640)
(16) Kinze 3000...
2000 Malibu (A62613)
Landhonor Quick Attach Seeder (A66285)
Landhonor Quick...
2018 Ford F-150 4X4 (A62679)
2018 Ford F-150...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
