Satoh Beaver 370D Won't Start
/ Satoh Beaver 370D Won't Start #1
Llamafarm
Satoh Beaver 370 D
I replaced the starter on a Satoh Beaver 370D with one that has gear reduction. Does this affect the spinning of the engine ? Could this be the reason it won't start ?
Thanks
/ Satoh Beaver 370D Won't Start #2
The new starter will spin it faster.. no, that's not the reason it wont start.. if anything, it'll help.
/ Satoh Beaver 370D Won't Start #4
I think the service manual provides step-by-step directions and you can used these step for repair and replacement of starter.
/ Satoh Beaver 370D Won't Start #6
if you have sufficient spark, fuel, and compression, it WILL start, you are missing one of those..
/ Satoh Beaver 370D Won't Start #7
It's a diesel, so "spark" isn't technically an issue.... air might be a good thing to have too:thumbsup:
/ Satoh Beaver 370D Won't Start #8
+1. Lack of or reduced fuel delivery is the place I would start looking.
Thanks for replies, will try suggestions and go from there :)
/ Satoh Beaver 370D Won't Start #11
Glow plugs...... most older engines need them even on warmer days.
Dave M7040
I second that as I own a Mitsu, while in decent condition and maintained it still wants glow plug heat in warm weather. (in winter it wants 2 cycles even with plugged in block heater). Otherwise a great tractor.
2021 Jayco Jay Flight 32BHS Camper (A62613)
2021 Jayco Jay...
2000 International 4900 Tandem Truck (A66285)
2000 International...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
(3) Corral Gates (A66408)
(3) Corral Gates...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
2019 CHEVROLET SILVERADO 2500HD (A65643)
2019 CHEVROLET...
