Backhoe looking to purchase TLB for 30 acre homested
   / looking to purchase TLB for 30 acre homested #31
HP not that important w/ industrial tractors. Would suggest oil analysis. Not very expensive these day, some owners are offended. Something to hide? Rather pay for a test than an engine, Check entire tractor for leaks, especially cylinders. Seals are often worn, allow dirt into reservoir/ pump. If oil recently changed, test results are skewed. Inquire if radiator flushed, coolant changed. ? Listen for plugged injectors, some did have head gasket issues, but most of those Cummins, good motors.
Know these older BH's can be money pits, eyes wide open.
   / looking to purchase TLB for 30 acre homested #32
-Check the brakes (can be a bigger task to fix than you might think).
-check the backhoe valve manifold for leaks. That can be a real pain to fix and expensive
- check for blow-by into the radiator or crankcase exhaust and water in any of the oils for that matter. At 4500 hours you got to think the piston rings would be worn if they haven't been replaced.
   / looking to purchase TLB for 30 acre homested #33
I don't know much about TLBs, sorry. But whoever made your driveway originally needs a swift punch in the gut, haha. Thats some lazy work to simply roll boulders to the side and make a trench, oy.
Good luck getting a machine. A 4wd 580 for $12k sounds like a good path forward.
   / looking to purchase TLB for 30 acre homested #34
63 HP in those lowish RPM industrial engines is plenty of power for anything. My JD 310 is only a little bigger and the only chance I ever get to use more than half throttle is when I'm roading it somewhere uphill.
4500 hours is nothing on JD, Case, Cat engines. Even less of a worry for the non-turbos. If it has seen anything close to routine maintenance and use you will have no fears on the engine. Just well broken in.
The thing to check is brakes, leaks, and how does the oil/water/hydraulic fluid look. For that price I'd expect it needs tires. In fact, the only thing that concerns me at all is why is the price about half what the market goes for? What are your thoughts on that??
If it runs good now - and from the jobs you say you will have for it to do - then I'd expect that in the next few years you won't put enough hours on it to make a difference. Keeping it away from neighbors wanting to borrow it for their own projects is likely to be a larger worry.
Again, the only problem I see is what I don't see....and that's the why of the price, again.
If it checks out, grab it. You sound like a good enough mechanic to deal with routine problems.
rScotty
   / looking to purchase TLB for 30 acre homested #35
That era of 580 tended to rust out in the floor of the cab and doors. Case also had quite a few backhoe control configurations: 5 stick, 3 stick and pedals, twin stick, etc. The 5 stick is one for piano players :)
They are good old work horses. Plan on doing a full service of basically everything. You'll probably have to replace quite a few hoses once your get using the machine, so find a place that can make them up for you that is close by.
   / looking to purchase TLB for 30 acre homested #36
I have approximately the same vintage 580D re-engined with the BT-4 Cummins-not 4x4 but extendahoe. Probably about 1500 hours on re-engine.
Brakes can be a major cost and PITA as well as loader and backhoe valve leaks. I have re-done brakes on mine and steering control valve seals. Overhauled dipper cylinder and boom cylinders-probably put 2500 into it in 3 years. Bought for 9000.
Great machines once you get rid of the for crap gauge panel that Case inflicted on these. I have dug probably a 1000 feet of water and power line trenches and moved, placed and graded 150+ yards of gravel. Love my hoe even though she’s a bit primitive of a beast. You’ll never lack for digging/lifting and pulling power- it puts the toy backhoes on CUTs and SCUTs in their place when it comes to working big or tough jobs.
   / looking to purchase TLB for 30 acre homested #37
Great machines once you get rid of the for crap gauge panel that Case inflicted on these. I have dug probably a 1000 feet of water and power line trenches and moved, placed and graded 150+ yards of gravel. Love my hoe even though she痴 a bit primitive of a beast. You値l never lack for digging/lifting and pulling power- it puts the toy backhoes on CUTs and SCUTs in their place when it comes to working big or tough jobs.
All real good info, GS. I didn't think about rust; probably because it's rare to see rust here in Colorado. Don't know much about it.
And of course 4x4 doubles wear points as does extendahoe. Keep in mind that other than brakes, these old machines were designed to be built and rebuilt. They can be a PITA, but they are simple beasts. Lots of shop manuals available because they tend to age rather than break.
My buddy bought a basic 310 2wd standard of of that vintage on which everything worked ... but it needed attention to everything, too. If it had ever been serviced or even regularly greased it sure wasn't obvious. Over the past 3 years he has replaced a lot of pins, bushings, seals, and hoses. None of which kept him from getting a ton of work done with it. He even built a thumb for it! The upside is that it now works like a much younger machine. Probably worth more, too.
My own 310 hasn't been without maintenance. Something to consider is that parts & pieces are HEAVY. Even the batteries (2) are heavy brutes. When I took the boom cylinder off for new seals (it had been moaning for weeks) - it required another loader to lift the cylinder & put it into the trailer to take to the shop. BTW, the problem with leaky seals is less that fluid gets out than that dirt gets in. The seals on that cylinder were about half original rubber and half hardened clay dirt that had to be chiseled out. No, it didn't leak. Nor was anything damaged. Just needed cleaning & seals.
Like GSvette says, find a local hydraulic shop for hoses and cylinder seals. Half the price of dealer parts. Around here most every rural town has such a shop. Lots of times they are right there in the same area as the dealer. Here you can't quite throw a baseball from the dealership to the hydraulic shop - but you can see his front door from 4 different tractor dealerships - Case, NH, JD, & Kubota.
Along with not lacking power, these industrial machines are hard to bend or break. I don't know the 580 as well, but as powerful as the 310 is, I think it would stall before hurting itself. Clean fuel & filters, good batteries, a block heater, flush the coolant, backwash the radiator, hoses & belts. Just all the normal stuff. You buy a good tractor for low dollars & you gotta expect those things. What matters is that it continues working and that you keep your mind set on appreciating what you have when it's back into shape. You put any of those older Ag or industrial machines back into shape and it will last for generations of homeowner style work.
good luck,
rScotty
   / looking to purchase TLB for 30 acre homested #38
Hi, Ofenback! I just came across this thread, and though I don't think I can add much in terms of expertise, I do know Kerhonkson fairly well. Spent plenty of time over the last 30 years at the resort up on Fordmore Rd. (working and playing), so I know the steepness of the terrain and the size of the rocks around there. I currently live in N. NJ, but my family has ~35 acres over near Liberty.
One thing I may suggest is to talk to Matt over at M&H Tractors off 17 heading towards Middletown. He has a used JD 310SE 4x4 that might fit your needs(if not too small?) listed for $20k, but maybe you can talk him down a bit? He also has a Case crawler / loader that may be useful for digging out those stumps, and maybe pulling trees if the winch is in good shape.
hudson valley for sale "845 313 3378" - craigslist
If you go, tell him Lee sent you.
rScotty,
You are absolutely correct. Jeffy operates in a flat enviornment. Never used a log arch but would not attempt to do so unless the tractor weight was equilivant to the log. Never on a steep incline. Log arch can rollover, as they are narrow by design.
Jeff obviouly has not experienced an implement or load of any type, push or pull the tractor on an incline, it is certainly an underwear changing experience, the real probability of a tractor rollover. Once it begins, very difficult to alter the outcome.
Forestry skidders are heavily built for a specific purpose. Have had some success w/ smaller crawler tractors due to the lower gravity center and significant traction footprint, their instant abilty to alter direction doesn't necessarily prevent the sliding once begun, but may avert rollover.
Logging large diameter timber isn't really a recommended amateur hobby for the inexperienced and ill equipped.
In my neck of the woods, mud ladden furniture grade logs are discounted, thus discouraged.
great advice and will be well heeded by me for SURE. I'm trying to enjoy this place, not die here under a tractor due to recklessness.
just to clarify, I didn't mean to imply that I would be "logging" large diameter timber or selling them for use by furniture manufacturers, just that I gotta get these trees off the dang banks so I can get em cleared and scape the driveway for better visibility, stability and drainage etc..
and in 99% of the instances i'l be dragging logs up the driveway with the banks still intact on either side keeping me somewhat safe in a little chute with nowhere to go but down. sounds dumb but my point is i'l never be sideways on the incline with or without a log arch.
the part about milling the lumber is somewhat ancillary. in essence, everywhere I look is a big tall beautifully straight tree and it's right in my way. many times it's right where I want to put up a shed, garage, cottage etc.. so the milling aspect is sort of palm to forehead territory.
in other worlds, it don't take a rocket surgeon to realize I should turn these trees into my outbuildings.
I don't even have a mill yet and when and if I do get one it will be the size/cap of a woodmizer LT-15 or similar. hardly the kind of thing for commercial productivity. anyway, in the meantime I've got a buddy with a portable HD-36 (I think?) so he'l be handling some of this for now...but that's a whole other thread!
anyway, thanks for your input, I just wanted to clarify.
thanks for the advice... yes money pits. I've heard it said that a 15k TLB will turn into a 25k TLB in short order...
can an oil analysis be done by a local shop or dealer?
most of these cylinders are pretty neglected and dirty. here's a pic of the BH portion of swing? cylinder on that 580E. (more on that coming soon)
is it common for folks to change fluids on these machines? all the machines I've checked out so far haven't been serviced In years. even the dealers don't service the machines when they come in and don't plan on doing it before they're sold. they want extra bread for that. again, I'm a rookie but it seems like it would be the EASIEST thing to extend the life/performance of any engine. I realized it's a PITA but gimme a break! it's a $10-20k machine.
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A56435)
2008 Ford F-250...
2013 John Deere 35D Mini Excavator (A55973)
2013 John Deere...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
2016 Chevrolet Tahoe SUV (A56859)
2016 Chevrolet...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
