Backhoe looking to purchase TLB for 30 acre homested
   / looking to purchase TLB for 30 acre homested
hey fellas, just getting the hang of posting pics. here's a few that tell the tale a bit better then my paragraphs. I'm working my way around to answering your questions and getting back to everyone who has replied but thanks for all the info and opinions, it's given me a bunch to consider.
take a look at these pics and lemme know what ya think, and if there's any other specific pictures that would help I can try to upload another few.
thanks as always and be safe out there!
Ofenback, you sound realistic enough to get the job done. It's just going to take looking in some unconventional & different places. You've got the land & that's the important thing.
Shucks, I'd like a Kubota U-55 myself. An excavator beats the pants off of any TLB for digging. But like you say, it isn't going to happen in most budgets.
When we had just bought our land and needed a machine but had not much cash money we started looking at ads 100 miles away in farm country and bought an old Ag tractor with a loader. It ran fine, but everything was worn. The corn farmer we got it from was using it as a stationary power source to drive a PTO-powered irrigation pump. He had parked it for that duty basically because it needed tires, & he had a newer tractor for field work. 2WD was OK because all those Ag tractors have massive traction at low speed. After all, traction in sloppy soil is what an Ag tractor is all about. Even the 2wd ones are scary impressive.
The tractor was $4K & tires & a battery another grand. I found a big heavy 3-way 3pt back blade at a local used implement dealer for another 2 thou. That was a score. My friend's 33 hp compact tractor couldn't even lift that blade on his 3pt, much less drag it in the ground. By contrast, our funky old ag tractor barely even noticed that blade was back there.
Then came the backhoe. In not much time we found several to choose from in the 2 to 4K range. We ended up with a medium small Bradco brand 3pt hoe - which turned out to be big enough.
In farming country there are always used 3pt hitch-mounted hoes on the market as well as a ready market for used ones. The trick there is that it takes something with the weight and beef of an Ag tractor to handle even a smallish real hoe on a 3pt hitch. And you have to be willing to put up with the inconvenience of the tractor and hoe not really being made to to complement each other. For example, ag tractor seats don't spin around and wouldn't do any good even if they did. You have to position the tractor, set the brakes, and climb down off the tractor.....walk around to the backhoe (which has it's own seat) - and then climb up on it, lower the stabilizers....dig for 5 minutes and then undo & repeat the whole operation in reverse to advance a few feet. But it sure beats a shovel.....
We used that Ag tractor with the blade and hoe for 15 years & got a lot of work done. Downsides are that it is a big old awkward tractor that took a dozen different arm and foot motions to get turned around. Working it was a workout in itself. This wasn't a machine made to be convenient. But the power & reliability were awesome. We eventually saved enough money to buy the machine of our dreams...a compact Kubota TLB M59.
So there are options. It's just that those farm oriented Ag tractors and their heavy implements aren't part of the 4wd compact tractor world. But they are common enough at rural farming communitiy tractor dealers and in rural newspaper ads.
My advice if you go the unconventional route is to choose the smallest and most rugged 3pt backhoe of the ones that find. And BE SURE TO TURN THE AUTOMATIC DRAFT CONTROL to OFF! when using a 3pt hoe.
Luck,
rScotty
thanks RScotty, I like the idea of looking in unconventional places. and I also like the beefyness of the AG tractors although I've heard horror stories from guys having to split them to fix something as there (supposedly) not much of a frame and I've also heard exactly what you said regarding the hoe on a 3 pt hitch. apparently folks have done some serious damage hanging a big hoe off the *** end of a tractor that was never meant to handle that kind of weight. doesn't sound like you've had much trouble with yours tho....
I don't mind the incovienience of having to do lots of maneuvering in/out/over/under/down and around the machine to do what I need, like you said, just trying to save my back and not have to dig it by hand.
let me know if these pics of rocks and stumps seem like they could be tackled with your older AG tractor and setup.
thanks!!
A $15k 4x4 TLB will become a $25k TLB in short order. Spend another $10k-$15k and you can get a nice machine that will last you a long time. My money would be on a nice 580 Super L or M.
OUCH!! yeah I hear ya. and I'm sure you speak from experience but what's a poor boy to do? if you were me and you didn't have the cheddar would you just save your pennies for the next 5-8 years while the work piles up or blow you wad on rental? anyway that's my predicament.
It does not take much tractor weight to pull large logs or stumps from the rear/center drawbar, if you do not mind the logs getting dirty.
My L3560 in photo is 3,494 pounds, bare tractor. Photo #1.
A Log Arch allows a tractor of moderate weight to transport clean logs suspended above the dirt. Good for transport to potential saw mill.
VIDEO: tractor log arch - YouTube
PHOTOS: compact tractor log arch - Google Search
great pics and great ideas. i don't mind logs getting dirty, I can hose em off before I have to cut... but do you think a solution like that will work for the size oaks I'm dealing with? these things are big and solid as they come
   / looking to purchase TLB for 30 acre homested #26
What a beautiful place you have! And that road is great - very high quality. Even a small compact could maintain that good of a road summer and winter. It might need chains, but that road is basically easy.
And a mature forest is a pleasure to work in. As for the log, figure that is a standard 4" diameter coffee cup and the log comes out at about 2 foot diameter. I'd say 20 feet long from cut base to rope snotter, and then half that diameter for the next ten feet. Wet oak density is about 60 to 70 lbs/cubic foot....we multiply things out and get a log weight of 5600 to 6500 lbs. Call it 5000 to 7000 lbs just to be safe.
Well, on the flat with a log arch Jeff's L3560 compact won't have any trouble at all with that much log on a log arch - he would just have to be careful that it never got away & started to move on its own. Although that size compact would struggle to flat out lift even half that kind of weight it can certainly pull it. But on any kind of an incline and on your road I'd prefer a tractor that outweighted the log and had larger tires & brakes as well. So that puts up back into the realm of the good old Ag tractors with loader & 3pt implements...
Not the perfect solution, but it will get the work done for the next 5 to 10 years while saving money for other things. That's what's a poor boy does....
luck,
rScotty
   / looking to purchase TLB for 30 acre homested #27
rScotty,
You are absolutely correct. Jeffy operates in a flat enviornment. Never used a log arch but would not attempt to do so unless the tractor weight was equilivant to the log. Never on a steep incline. Log arch can rollover, as they are narrow by design.
Jeff obviouly has not experienced an implement or load of any type, push or pull the tractor on an incline, it is certainly an underwear changing experience, the real probability of a tractor rollover. Once it begins, very difficult to alter the outcome.
Forestry skidders are heavily built for a specific purpose. Have had some success w/ smaller crawler tractors due to the lower gravity center and significant traction footprint, their instant abilty to alter direction doesn't necessarily prevent the sliding once begun, but may avert rollover.
Logging large diameter timber isn't really a recommended amateur hobby for the inexperienced and ill equipped.
In my neck of the woods, mud ladden furniture grade logs are discounted, thus discouraged.
   / looking to purchase TLB for 30 acre homested #28
rScotty,
I gotta agree with most of that - especially that operating on an incline can be an "underwear changing expeience" :) nice visual image, major.
Although my guess is that with Jeff's experience he probably has been on & understands inclines. The fact is that tractors on inclines are a whole different world. Compacts especially are just not built for inclines. We tractor nuts do use them on inclines though - maybe this is a case of being a little bit smart and a whole lot stupid. The thought of a log arch crosswise on an incline gives me shivers.
I know I'm about as experienced and careful of a tractor operator as half a century can make me. And in spite of that last winter I got sideways on my own inclined driveway and ended up sliding sideways about 50 feet to where it leveled out. Ditches on both sides but the big tractor stayed in the center....luckily. It's a big stable tractor, so no worry about overturning....but scary to be so out of control & going sideways.
rScotty
I got a lead on an 87 Case 580E. got the extendable and 4x4. going to look at it now, was told it's in decent shape. it's a friend who knows the seller, friend says he trusts the guy, sold him a tractor years ago.
anyway, we'll see. it's got 4500 hrs on it and priced for 12.5, perhaps I can get it for less.
this has the cummins 4.39 and about 63 HP and I believe and the geared transmission with shuttle shift. not sure if that means it has a TC or not.
does 63 HP seem like enough to move a 7 ton machine with buckets of rocks up and down a slope for a few years?
anyway, just wanted to see what the pos/neg are for a machine like that.
thanks as always for the thoughts.
closest dealer is approx 60 miles away.
PALLET OF CULTIVATOR PARTS (A52708)
PALLET OF...
Toro San Pro Bunker Rake (A56857)
Toro San Pro...
WhisperWatt DCA-85SSM 85kVA Towable Diesel Generator (A55973)
WhisperWatt...
EquipmentDealz (Preview Dates and Times) (A59213)
EquipmentDealz...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
2007 Yamaha Rhino 660 (A56435)
2007 Yamaha Rhino...
