Foton FT404 electric fuses problems
/ Foton FT404 electric fuses problems #21
Didn't find a thread more appropriate, so I'll just write my experience here. I swapped the original Foton 404 alternator for a bosch internal regulated one (B+/D+ wires only). Seems to be working well. I spliced into the switch ON positive to feed an "idiot light" and wired the other wire of the light to D+ post on alternator. B+ is the same as before for the original alternator.
I added a cheap chinese volt meter to check the voltage from cabin, it fit right in to the dash in an empty button rectangle. regulates to ~14.2v without any load, drops to ~13.8v with high beams on.
/ Foton FT404 electric fuses problems #22
Thanks for the info, what model Bosch did you use?
Did the original brackets work? I had to make custom brackets. I'll look up the Bosch alternator , and it's connections
KUBOTA Z121S KOMMANDER ZERO TRUN MOWER (A65054)
KUBOTA Z121S...
300# SPIN SPREADER, 3PT (A64278)
300# SPIN...
2018 MULTIQUIP TOWABLE GENERATOR (A63276)
2018 MULTIQUIP...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A64194)
2013 Chevrolet...
2022 EZ-GO ELITE...
Wooden Glider Chair (A64557)
Wooden Glider...
