stubby auger
/ stubby auger #1
IanM
Member
Kenwood California
Kubota L2550GST
I need a pto driven auger that can access a 36" space. This would save me tons of labor costs. I'm planting 1,000+ grapes in-between vines of an established vineyard. The trellis system, which I can't remove, is a quadrilateral arrangement 36 inches off the ground and 18" wide. I only need a hole 12-16 inches deep and 12 inches in diameter. My Howse post hole digger run by a Kubota L2550 would do the job if the auger was shorter. I've done a quick search but haven't found anything commercially available. I'm looking at fabricating something and hoping for some suggestions.
Thanks for the help.
/ stubby auger #2
Have you looked at the augers from the smaller manual post hole augers and making an adapter to fit? The old 2 man style catch and break your arm! Kind
/ stubby auger #4
I just measured a bit for a Groundhog auger, it's 36". It might be worthwhile to buy one and cut it down and put the correct collar on for the pto drive. A specialty 14-16" bit can save a lot of time in positioning on 1000+ holes, and can be part of the bid.
/ stubby auger #5
mini skid steer unit, try your local rental yard and see if they can let you rent just the bit.
Augers
/ stubby auger #6
Cut your 12" auger down. I just cut one up to make a 12" auger reach a true 48" in depth. Fairly easy to do. Cut the spiral off and then shorten the drive shaft and reweld.
/ stubby auger
I think that makes the most sense. It will be a nice rainy day project.
2018 Peterbilt 579 Sleeper 72" Sleeper (A62613)
2018 Peterbilt 579...
2016 PETEBILT 579 69 SLEEPER (A62613)
2016 PETEBILT 579...
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
2006 Sea Ray Sundancer Boat w/ Loadmaster Tri-Axle Boat Trailer (A61574)
2006 Sea Ray...
3PT HYD SCRAPE BLADE (A63291)
3PT HYD SCRAPE...
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
