B3030 help needed
/ B3030 help needed #1
BAYOUBENGAL
Perry, GA
B3030
Was trying to hook up my rough cut and tried to turn the pto a bit to align. Forgot I had to be in seat. Safety switch worked as advertised and shot tractor off. Now I cant get tractor restarted. Battery not dead. Can稚 get it to turnover or even engage. Anybody have any ideas?
/ B3030 help needed #2
To start my machine the pto must be disengaged... did you forget to turn it off by chance?
/ B3030 help needed #3
Make sure neither length of seat belt is under the seat, lifting seat just enough to open electrical circuit.
/ B3030 help needed #4
Make sure the HST isn't in gear, check to make sure your seat switch is OK and nothing stuck under the seat. Make sure the PTO selector is fully disengaged.
I do this all the time on my tractor and I just reset the PTO lever and put it in N with brake on and restart and resume.
/ B3030 help needed #5
As D85 says, make sure the pto selector is fully disengaged. Rock it back and forth and make sure it is seated in the off position.
/ B3030 help needed
Thx for the replies. Pto is off. Haven稚 rocked it or looked for seatbelt etc under seat.
/ B3030 help needed #7
1. Check the wiring from safety switch under seat to its connector to the wiring harness. Unplug it and plug it back in a couple of times. I have seen where the wiring has been severed by the seat.
2. Disconnect the battery. Wait a few minutes and reconnect.
Hope this helps.
/ B3030 help needed #8
Make sure HST foot pedal is at "neutral" position.
/ B3030 help needed #9
Check the ground from the battery. Had mine work fine when shutdown, then fail to start the next day. Burned lots of time finding weird low voltages all over with a multi-meter. Then loosening & tightening the bolt holding the ground to the frame fixed it. No corrosion or loose connections to be seen.
Go pedal not being quite in the middle is another big one. Sounds like you are aware of the seat safety. Might hit that with a multi-meter to make sure its switching as designed.
JOB BOX (A62130)
JOB BOX (A62130)
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
INOP/NON-RUNNING 2004 Freightliner M2 106 Medium Duty Day Cab Truck, VIN # 1FUBCXDC24HM93001 (A61165)
INOP/NON-RUNNING...
2014 REITNOUER 48FT T/A FLATBED TRAILER (A59909)
2014 REITNOUER...
John Deere 6125R Tractor (A64047)
John Deere 6125R...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
