Tire Balast
/ Tire Balast #21
Rim Gaurd
So did they specify that the tires had to be filled or that tires had to be filled with RG? If so, was it part of the price of the tractor or did you have to pay extra.
What does Rimguard cost nowadays.
/ Tire Balast #22
Since Yanmar specs it they put it in I had no choice. The price was not broken out in the quote or invoice. I did some digging and found the article below. According to this article in 2017 expect to pay around $3 per gallon for RG. According to the "Tire Fill Chart" on the RG site my tires 14 X 7.5 use 22 gallons each for 44 gallons total at $3 per gallon that's $132 total. My memory is that my dealer estimated $125 for the 424 so that's the ball park. Here is the article :
Tire ballast makes flowers bloom | The Western Producer
Here is the link to the TIRE FILL CHART at the RG website: Tire Fill Chart - Rim Guard
/ Tire Balast #23
The dealer chose Rim Guard.
/ Tire Balast #24
If I am looking at the right rear tires for your Kubota 4330 your rear tires take 47 gallons each for 94 gallons total @ $3 per gallon = $282 estimated. Not sure about the labor to install it.
/ Tire Balast
Those prices sound in line with a quote I got in Western Washington the other day.
/ Tire Balast #26
Correct, 47 gallons each tire.
So assuming 10.7 lbs/gallon, that's 94 gal *10.7 = 1005.8 lbs at $282 = $.28/lb. Not too bad, IMO. Far, far cheaper than metal wheel weights.
Thanks for the info!
/ Tire Balast #27
But the most important is NON CORROSIVE.*
Much cheaper than new rims down the line.
I question the price as my 9,5 X 18 turfs were filled with 'beet juice' aka Rimguard at a cost of $54.00 (Cdn) (but then they charged me $30 to dispose of the calcium).
4 years ago.
*my rims, while salvageable, were not pretty.
/ Tire Balast #28
4 years ago.
The RG site doesn't list your tire but does have 9.5-16 and 9.5-24 so 9.5-16 is 24 gallons total or $72 dollars. So definitely you go RG better than the estimated. I travel to Ontario quite a bit and if I remember correctly the C$ was stronger than the US$ back then but probably not as much as the price differential we are talking about. Also the $3 number is a round "market" price subject to negotiation I would be curious what a dealer actually charges, probably something slightly less. Also the labor to fill the tires should cost something its more involved than filling with air.
/ Tire Balast #29
I had my tire change done at a large truck center that also serviced tractors.
I'd suspect that tractor dealers would not be as well equipped and possibly even farm out tire work and therefor probably add a mark up profit.
The truck center had big machines that removed and installed the tires (just like they do for cars) but about 3 times larger.
They also had all the pumps for the beet juice.
All in all I was in and out in less than an hour (and that even included wire brushing the rims and painting them to provide protection against rust).
/ Tire Balast #30
We are looking at a 60 hp tractor. The rimguard/beet juice will add a little over 500lbs per tire. They say 55gal/tire.
My calculation is that Rim Guard is 10.69 pounds per gallon. Water is 8.34 pounds per gallon. So 55 gallons of rim guard is like 588 pounds. Closer to 600 pounds if thats correct.
/ Tire Balast
Don't remember the numbers exactly but it sound really close to what I was told by installation company
/ Tire Balast #32
for those that have loaded tire did you just do the rears? cause wouldnt you loose capacity on the front tires with a big load in the front bucket?
/ Tire Balast #33
Kubota recommends not loading the front tires. I did it anyway. About 12 gallons each. Kept the front wheels on the ground better than 60 gallons of water in the FEL bucket when bushhogging my hills and a lot less of the "porpoising" when driving somewhere.
/ Tire Balast #34
I only did the rears on my 5083 with rimguard. I run 8 100lb suitcase weights when brush hogging if I have the loader off. I think I still have room for 4-6 more if I needed it.
/ Tire Balast #35
I plan to get Rim Guard for my small tractor if I can find it. It gets "floaty" in the rear with a lot of rocks or dirt in the bucket. The tires won't hold much but any is better than none. I might add some wheel weights, too.
You really need to put some weight behind the rear axle so that it counterbalances the load on the front wheels. Putting ballast in or on the rear wheels does nothing to remove weight from the front axle. It may be enough to keep your rear wheels on the ground, but the more weight that you have on the rear axle without a counterweight (think box blade, bush hog etc) the more you can load your front axle which can easily cause damage if the OEM specified maximum loaded weight is exceeded.
2016 Chevrolet Silverado 2500HD 4x4 Crew Cab Knapheide Service Truck (A68183)
2016 Chevrolet...
2025 Grapple Rake Mini Excavator Attachment (A66734)
2025 Grapple Rake...
2006 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A67714)
2006 TROXELL 150...
PORTA POTTY (A68842)
CAT 613B Transmission (A68134)
CAT 613B...
2010 Brenner Aluminum 407 T/A Chemical Tanker Trailer (A68183)
2010 Brenner...
