Good morning!!!!
   / Good morning!!!! #75,621
Wngsprd
Whole house filters, easy to get off Amazon and your plumber should install easily. We use the 20 inch Big Blue housings
   / Good morning!!!! #75,622
Drew, am I correct in remembering that you replaced a bathroom fan and found a nice quiet one? If so, do you remember the brand? I have one that is making a grinding noise, and will check it out, but likely just replace it once I take it down.
I used panasonic. Very quiet. Could install most from underneath, had to go in attic to remove old fan.
   / Good morning!!!! #75,623
i hear Panasonic builds good vent fans...but pricey.
   / Good morning!!!! #75,624
David- I really like your inline filters set up. I think you mentioned your setup previously. Are you filtering out specific water impurities? Your water must be pretty "pure."
Our filter system is a basic set up with a bypass.
   / Good morning!!!! #75,625
Thanks Jay.
Nothing in particular. We do catchment from the roof so mostly precautionary.
   / Good morning!!!! #75,626
Really busy right now unscheduled surgery on my back healing nicely drain tube out human body is a funny thing. This put on hold removal of latest skin surgery removal by two weeks
We have a whole house filter system for grit acid water etc. system works very well limited maintaince required. Never stopped working cannot afford to would get too far behind
Very dry around here another fire burning north of us 1600 acres and growing
Prayers for all those in need
Saw smoke from a fire in the mts south of I64 yesterday.
   / Good morning!!!! #75,627
Faucet vs tap somewhat interchangeable since I grew up. BUT
Always a faucet in the store and on my beer keg it’s a tap
   / Good morning!!!! #75,628
A water tap here is a connection to a water main.
   / Good morning!!!! #75,629
So update:
Seeing a light vog over the horizon. Have noticed a whiff of something different in the air from time to time but nothing heavy or persistent. Not a hydrogen sulfide odor, but a tad acrid and goes away. Had worse when one of my neighbors burns in his wood stove. TV wx people mentioned possibility of acid rain but not so far. Unless wind changes significantly we shouldn’t have a problem.
   / Good morning!!!! #75,630
David- Thanks for the pictures and response. Now it makes a lot of sense. I am assuming that you have a cistern or other means of water storage. :cool: setup Thanks
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
Daewoo GC255 (A53314)
2015 John Deere 410L 4x4 Extendahoe Backhoe Loader (A55787)
2015 John Deere...
2025 60 Gallon Poly Diesel Tank w/ 12v Pump (A55787)
2025 60 Gallon...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A55852)
2012 Crane Carrier...
2014 Volkswagen Jetta Sedan (A55758)
2014 Volkswagen...
