Rounded off drain plug
/ Rounded off drain plug #222
Truck is back home, head replacement, wiring repair, fuel filter, fun stuff. Took friday and the weekend off. Plan is to pull the tires off the tractor and get them settled, then talk to the shop down the road about welding a nut over the bolt and removing it that way.
Hooray!
/ Rounded off drain plug #224
Did you ever get the drain plug removed?
Not as of yet, tire and rim are still out, shop is looking at doing some patching on the rim.
Here's the state of the rim. I don't know if it would be worth sandblasting and patching at this point. Getting a normal set of rims wouldn't be an issue unless I want to use the plow. Current rims were adjusted for the 2 bottom we have.
There's a bit more cracks and thin spots on the side wall of the rim that I didn't take a picture of.
/ Rounded off drain plug #227
Those are about the worst wheel I have ever seen. I'm going with buy new ones unless you are a capable welder with experience and a pile of sheet steel plus a press to make those repairs. Owning equipment sometimes costs money for repairs and this looks like one of those times but that's just my opinion.
/ Rounded off drain plug #228
View attachment 552052View attachment 552053View attachment 552054
What is the reason you can't leave them set at the plowing width all the time? Do you need them spaced different for some type of row-crop work?
/ Rounded off drain plug #229
I would only attempt to fix that if there was no way to buy an new one. Repair will cost more than a new rim if you have to take it to a shop.
/ Rounded off drain plug #230
Those rims don't even qualify as JUNK !!!
/ Rounded off drain plug #231
That is about the same condition as my old camp fire ring.
/ Rounded off drain plug #232
Putting air in the tire would give me the willies after that was was repaired!!
/ Rounded off drain plug #233
Me too!
For the cost of new wheel loops, I'd just go with new ones. I don't even remember what kind of tractor the OP has anymore, but even if he had to buy wheel loops that had the incorrect fastener spacing and just have a weld shop relocate them to the proper positions he'd still be money ahead of trying to repair those.
/ Rounded off drain plug #234
I gotta show Kando my sympathy for his drain plug issue,,,, by throwing gasoline on the fire,,
My Onan powered Gravely 24G has two engine drain plugs, one I can remove, the other I can not budge,,,
I have been able to use the engine since I can drain the oil with the left plug.
The right plug, being located in that recessed area, can NOT be budged.
The problem with the plug not being able to be moved? the plug LEAKS!!
I get a tiny puddle under the machine after it sits,, so I have learned to park it on cat litter,,,
I would love to fix the leak, but, the risk of damaging the aluminum oil pan is too great.
So, I live with the leak,,, :confused2:
:D
Maybe a solution for Kando is to do what my Gravely has,, add a second drain plug!!,,,, :eek:
:cool2:
What I meant was that new unadjustable rims might not have the proper width set for the plow. However, I'm sure I can repurpose the other spin out rim on the tractor and switch it to the other side, then adjust it where I would need it and put a normal rim on the left side.
/ Rounded off drain plug #236
I think even if you have to go with new loop style rims, they will still be fully adjustable in 4 inch increments (2" per side) and can be set up for a 2-bottom plow. You should be able to set them either 52" or 56" for the plow.
I would not go with solid fixed/non-adjustable rims if you can avoid it.
/ Rounded off drain plug #237
I've welded on several rims, last summer I spent 10-12 hours welding and grinding on one for my 574 that said, I would consider that rim almost unrepairable and replace it with new or good used.
Luck
/ Rounded off drain plug #238
Me too!
I think the op's situation is that his rims are the early style Ford spin-outs, not loop type. It can be hard to find new rims to match the spin-out center rails. That would be the way to go, if available.
Some times if only a sector of the tim is rotted you can weld in a section cut from another used rim of the ssme size, relocate valve hole, etc.
/ Rounded off drain plug #239
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63689)
PENDING SELLER...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
2022 EZ-GO ELITE...
2018 VANGUARD REM VXP 53FT T/A DRY VAN TRAILER (A59914)
2018 VANGUARD REM...
