Wheel weights for a Kubota MX5800
/ Wheel weights for a Kubota MX5800
Triple R, are your tires loaded as well? Grumpa, thanks for the pics, looks sharp. Are your tires loaded as well?
/ Wheel weights for a Kubota MX5800 #22
I modified the starter weight on a set of old enfo weights and put on my MX. But I didnt do it for loader stability. I did it for more traction pulling logs, and pulling the transport disc and 3-14 plow with loader off.
I dont know what your terrain is like, but it would seem like nothing is needed. half a face cord is ~1/6 of a cord.
Average cord weighs 3500#.....so you are only looking at ~600#.
If I understand correct you dont have anything on the back because you dont want to bang around a tiller or box blade right?
My two suggestions would be 1. fill a barrel of concrete and attach to the 3PH for your counterweight.
or 2. Buy, or build a carryall and carry wood on the back of the tractor. Load it first, then load the loader
/ Wheel weights for a Kubota MX5800 #23
LD1, I usually only have the quick hitch off the rear. I have a smaller cement block that I've used on there (needs some frame fabrication) that I bought off an older gentleman with a smaller John Deere. Sometimes the turns are tight in the woods, so I don't want anything large. I understand you math, and I can't speak for exactly how much it weighs. We've been hauling ash, most of which is dead, but some is heavier/alive. It's mainly backing out of areas going up the inclines that gives me any trouble. If it's flat ground I'm good. I'm hoping to get to a happy medium where I don't "need" rear ballast to do work in the woods. The extra weight has helped push into dirt piles to drive better as well. Thanks for the input.
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
1974 Ford F600 Grain Truck (A61307)
1974 Ford F600...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
We do NOT accept credit cards as payment. (A60462)
We do NOT accept...
2000 Hyster S50FT (A55973)
2000 Hyster S50FT...
2014 VOLVO VNL (A60736)
2014 VOLVO VNL...
