LS XJ2025 backhoe bucket.
/ LS XJ2025 backhoe bucket. #1
Jarv
Redding, CT
LS XJ2025
I know there is an option for a 9" bucket, anyone seen a smaller bucket that can be used for trenching?
/ LS XJ2025 backhoe bucket. #2
Depending on your soil, a bucket narrower than 9" can pack full and render it useless. If you have any clay, you will get one pass before you have to get off and use a shovel to clear the bucket.
/ LS XJ2025 backhoe bucket. #3
You could try spraying the bucket with Fluid Film. I have lots of clay and it helped.
/ LS XJ2025 backhoe bucket. #4
Hopefully, more attachments will become available for our tractors. I think a ripper tooth for the backhoe would be great for stump removal. I see they have them for Kubota and John Deere so far.
/ LS XJ2025 backhoe bucket. #5
Its been a few years, but LS did not have anything smaller than the 9" bucket.
I believe the boom is wider than 6", so the digging depth would be limited with the 6" bucket.
/ LS XJ2025 backhoe bucket. #6
If you are digging in dirt that sticks in the bucket you can install small chains crossing the bucket so they fall into the bucket when positioned to dig but when bucket is rolled back to dump the chains tighten pulling the dirt out. Works on clay here well.
/ LS XJ2025 backhoe bucket. #7
Brotek probably has a ripper tooth that will fit. If not they will make one for you. They didn't list a ripper tooth for my Boomer 20 but it is the same backhoe as a MF CB65 (which they make a ripper for) so it fit perfectly. I used the ripper for trenching 250 feet to lay some cable and it worked great. I know that the boomer 20,24,and 25 are the same tractor as the LS so possibly the backhoes are the same as well.
/ LS XJ2025 backhoe bucket. #8
Nice looking ripper. How big of a mess does it make? Can it actually make a narrow trench or does it close back up like using a sub-soiler?
/ LS XJ2025 backhoe bucket. #9
I only trenched about 8 to 10 inches deep. I dug down with the hook to loosen the soil then while the ripper was still in the ground I curled the ripper till it was perpendicular with the ground and used a lifting and sideways motion to clean out the trench. It worked very well but is kinda hard to describe. They also make trencher wings that bolt onto the ripper to clear a wider path but I did not buy them. I actually got this ripper for tearing out roots when removing stumps.
/ LS XJ2025 backhoe bucket. #10
Thanks. I need trenches on occasion but also want to cut the roots on tree stumps. Sounds like good choice for a multi-tool.
View attachment 551153View attachment 551154
Great idea, I'll look them up. Thanks!
2019 International LT625 Sleeper 48 (A62613)
2019 International...
2016 FREIGHTLINER CASCADIA (A65643)
2016 FREIGHTLINER...
2000 FREIGHTLINER CENTURY CLASS 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2000 FREIGHTLINER...
2008 Mazda 5 (A62613)
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2021 ROTAIR D185 AIR COMPRESSOR (A65643)
2021 ROTAIR D185...
