California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 16,687
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
My little YM186D had this front-hinged seat with only the bare pan remaining after 35 years. That hinge allowed the seat to wobble side to side, and the foot pads are too far forward to stabilize the wobble with weight on my feet like you would in horse stirrups. My back muscles were always sore after a while.Many compact tractors have a simple seat with a hinged front and the back of the seat sitting on two coil springs. There is enough space between the two coil springs to add a third spring, sponge block, or even a damper.
I bought a suspension seat at Tractor Supply, $89 on sale. (I see similar seats on Ebay are listed to fit all Fords 9N through 5000).
This seat was far too high for my use. I need to drive under my orchard trees. So I took out the suspension springs (similar to an office chair with adjustable back-tilt) to let the seat ride on its rubber bottoming-out bumper. It's now a couple of inches lower than shown in the photo below, still several inches higher than the front-hinged seat pan that it replaced. This seat's solid base mount plus the armrests to stabilize an elbow against, reduce that back strain that was caused by the seat wobbling. The additional height helps load some weight on my feet, to also reduce wobble.
I took the photo below halfway through fabricating the mount for the seat. The back of the track bolts down to an existing threaded hole in the crossmember. For the front I drilled the existing upright and put an eye-bolt in it that goes back horizontal to where a vertical bolt from the track attaches to it. The (optional) power steering diverter valve is under there. The front of the track could be much lower if that weren't in the way.
Results: Recommended! Far less of that back strain fighting to stay upright on that wobbling original seat.
Photo: before completing the install.
