anyone convert a drill press to a lathe?
/ anyone convert a drill press to a lathe? #1
Paddy
Bloomington, IN
Kubota, G5200, KAMA 454
I'm looking to mount a face plate where the drill chuck would go. The thread is 1/2-20
/ anyone convert a drill press to a lathe? #2
Not sure what you have in mind, but typically the bearings in the nose of a drill are made for compression, and do not stand up to a side load like a lathe would subject the bearings to.
David from jax
/ anyone convert a drill press to a lathe? #3
I was thinking of flexing in the shaft too as a drill works close to the material unlike a lathe, also the head of a lathe is mounted on the bed and a drill it is the motor.
/ anyone convert a drill press to a lathe? #4
As was mentioned before a DP shaft bearings are not designed for lateral force. Probably only for work making light cuts; if you figure out a way to operate the cutting tools which would be all manual. I have used mine for light milling but the results are a long way from perfect. Some expensive drill presses are set up for precision milling but not the ones most of us work with.
Ron
/ anyone convert a drill press to a lathe? #5
are you using it for metal work or woodwork? shopsmiths are drill presses and lathes.
/ anyone convert a drill press to a lathe? #6
Agreed. The drill press spindle will deflect too much. I don’t even think it would work well for light cuts on wood or metal. Even a heavy duty drill spindle will deflect to follow a cored or spotted hole. This is the wrong tool for the application.
/ anyone convert a drill press to a lathe? #7
I have seen it done for things like filing dog points on setscrews, and with a center on the table and a flat bar in the vise along the work for woodturning small things like fishing lures. If you are just making small things and not putting a lot of load on the drill press, yes it can work...basically stuff that is small enough to fit in the drill chuck. I think a faceplate would be asking for trouble.
If you are doing woodworking, 12" craftsman lathes are freaking everywhere, and cheap. I picked one up for $40 at a local(ish) used tool place, but I have seen a bunch on craigslist too.
As far as metal lathes that can be a little harder, but if you were closer I know of one, 100+ years old, currently outside, some missing and broken parts. Seller won't ship because it's about 3500 lbs...
/ anyone convert a drill press to a lathe? #8
I have done that often but only under small pieces like to maybe do minor diameter adjustments.
As an example (using a file) to adjust, say a bolt or pin to adapt SAE to Metric or Metric to SAE.
More than that I use my lathe, either wood or my small metal one.
If I do use the drill press it is just because I'm too lazy to set up a lathe. (like it is 10 ft away and the other in the basement) LOL
I plan to turn marble, as in stone. The loads would be in compression. I want to mount a 3/4 in thick pc of marble on the face plate.
I'm trying to take this pc of green marble and get a water ripple effect.
I have had some success using a Radial arm saw auxiliary shaft (opposite the blade shaft). I use a round router bit or burr bit with the motor fixed. The table is a lazy Susan that I rotate. As I move the rotating table and adj the bit height, I get the rings close to the water ripples. So this is good for bulk removal but to remove the finer parts, it needs to be free hand.
The end goal is to have this green marble smooth and polished looking like pond water ripple. My wife, jewelry maker will then make some copper frog legs, so it looks like a frog has jumped in the murky green water making ripples.
I carve stone and try to come up with designs that are,,,,,different.
See attached sardine can
/ anyone convert a drill press to a lathe? #10
There is a site called homemadetools.net and if you go on there and search for drill press lathe you will see many different attempts at homemade drill press lathes it's kind of a neat site for the DIY home built on a budget crowd
/ anyone convert a drill press to a lathe? #11
You could build from scratch with a motor, a pile of pulleys and v-belts, some "pillow block" bearings, and some keyed shafting (so you don't have to try and mill your own keyways). For a final shaft with a 1/2-20 end, use a fine thread bolt, or get a buffer adapter. The pillow block bearings will be designed for the side loads from the belts and cutting tools.
For slowing down a motor to working speed, put a small pulley on the motor, and a big pulley on the next shaft. That shaft will be slower by the ratio of the pulley sizes. Then keep adding pulleys and shafts until the last shaft is going the speed you want. You can swap out pulleys to change speeds, or get a set of step pulleys to go between two of your shafts (or between the motor and one shaft). You can put the step pulley pairs at each belt if you want more speeds to pick from.
But by the time you do all that, you might be money ahead to have bought a used wood lathe. The advantage would be being able to make just what you want. Also, if you are a good scrounge, you can find pulleys, belts, bearings and shafts from other sources such as appliances. If you are going to be working wet, you could have the shaft come up from below into a cut-off bucket or barrel to contain the spray, as long as you had another pipe sealed to the bottom at the middle for the shaft to come up through, so water wouldn't drip onto your belts.
Shafting:
1/2" x 36" Keyed Shafting | Keyed Shafting | Shafting | Power Transmission | www.surpluscenter.com
Buffer Adapter:
Eazypower 8142 5/8" or 1/2" Motor Arbor Adaptor RH Thread (1-Pack) - Motor Shaft - Amazon.com
/ anyone convert a drill press to a lathe? #12
China made wood lathes are very cheep, and at least they are a lathe to start with, so why bother with a drill press...
SR
/ anyone convert a drill press to a lathe? #13
I have seen some rubbish Chinese lathes with the pressed steel bed, do not align well and flexing can be an issue, if you can find one with a cast bed it will be much better.
Also with a converted drill press you won't be able to do outboard turning as the head is fixed which will limit the size of the stock you want to turn, as you mentioned a plate I am assuming you want to turn bowls.
My drill presses both have morse tapers for the chuck so a plate should drop straight in although I am not sure what size the taper is, most (lathes) use a #2 although my small Record uses a #1.
/ anyone convert a drill press to a lathe? #14
Looking at your picture of the marble sardine can, was the device i would use for that is what i would call a milling machine, but that may just be semantics.
cqaigy2
The sardine can was made from a variety of tools. The outside, rim down was made on a radial arm saw. With the block upside down, saw was set for 10 deg angle.
Inside was removed by drilling a zillion holes, using a air chisels. Finally smoothed by a mini diamond cup wheel on the drill press using the dept gage as a stop.
The lid that is rolled was free hand using air chisel.
Each pc I do is just for fun and I end up using tools in unique ways.
Having a slow turning lathe, 60 to 100 rpm, would open the door to other carvings I want to "attempt".
If making one from scratch, I'd look at using a wheel hub with a wheel rotor as a face plate. Getting the speed down takes a bunch of pulleys.
/ anyone convert a drill press to a lathe? #16
cqaigy2
Look on Alibaba. It looks like you can get a small mill (which is like a beefed up drill press with a screw driven x/y table) for under $500. If you watch Craigslist, you might be able to find a similar deal, but it will probably be a lot bigger.
Aaron Z
to better explain what I'm wanting to turn. See attached photo of water ripples. Imagine turned out of 3/4 inch stone, 12 in square
/ anyone convert a drill press to a lathe? #18
In woodworking this is called a bullseye rosette cutter but it is on a smaller scale you could probably make one yourself you would need a piece of tool steel large enough to grind your profile out of (cross section through the ripples) and then using your drill press take a very very slow cut?
/ anyone convert a drill press to a lathe? #19
Keep an eye on Craigslist. I bought a Clausing 12" lathe several years back for $400. It would be great for what you are doing.
/ anyone convert a drill press to a lathe? #20
I am concerned that a lathe may not be exactly what the O/P needs. Yes, a lathe is what he is wanting, but I am thinking that a mill may do everything that he is wanting, and more. It may not do the turning quite as quickly, but with a rotary table, a mill will usually do a larger piece than a small lathe can handle. A multi-directional mill may work out better for him. A Bridgeport is a 3-D machine, but several manufacturers built even more angle and directional machines. I gave a Fray All Directional Mill to a good friend who needed one, and Maho and several others made a Universal Mill. I think these might be a better choice in the long run.
I wish the Paddy lived a little closer and I could make him a really good deal on a Maho Universal Mill. I sold one, and the buyer changed his business direction before he picked it up. It can be bought! Shipping is the issue.
David from jax
2019 CM TRAILER CARGO TRAILER (A60736)
2019 CM TRAILER...
2006 International 7600 T/A Flatbed Truck (A60352)
2006 International...
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
New/Unused Landhonor 20ft x 20ft Carport with Side Walls (A61166)
New/Unused...
2020 CATERPILLAR 262D3 SKID STEER (A62129)
2020 CATERPILLAR...
2014 JLG 10054 SKYTRAK TELEHANDLER (A60736)
2014 JLG 10054...
