6410 steering cylinder removal
/ 6410 steering cylinder removal #1
hozjob
Member
PineBush, NY
John Deere 6410
I need to reseal the steering cylinder on my 6410. How do you get the cylinder removed from the axle housing?
/ 6410 steering cylinder removal #2
hozjob
There are different options for the 6410, and a screen shot of those from jdparts is shown here. A pic of what you have also may help, but more info possibly needed.
John Deere - Parts Catalog
AL113744 is the part I'm trying to remove
/ 6410 steering cylinder removal #4
Ahh, see it. And nut key#1 or #3 won't come off?
I've got the nut off, just can't get it out of the housing. Wasn't sure if there is a trick to it? or if I'm missing a pin or some other type of keeper.
/ 6410 steering cylinder removal #6
Please report how difficult the proceedure was in the end. Mine leaked quite bad. I suspect dirt gets on those rods easily and takes out the seals. Anyway, I took one look at it and brought it to my independant Menonite JD shop.
/ 6410 steering cylinder removal #7
Did you remove both banjobolts from the silinder ?
/ 6410 steering cylinder removal #8
No, sorry. I took the machine to an (experts at JD) Menonite shop.
I found the cylinder itself was fairly easy to reseal.... if you do it while it's on the axle. However, removing it from the axle housing has me beat.
