51R Battery for JD4100
/ 51R Battery for JD4100 #1
coloradotrout
Gold Member
Eastern KS
JD 4100 HST CUT w/Yanmar 3TNE74 | JD 300 Lawn
I have been using Optimal yellow top, but at $250 now I'm wondering if a $125 battery might be more cost effective. Thoughts?
/ 51R Battery for JD4100 #2
I like the Optima Yellow top batteries. I have 2 diesel mowers with 51r’s in them, and my Kubota L4060 will get a yellow top when I replace the oem battery.
Are they more cost effective? Likely not at twice the price, but the low self discharge rate and deep cycle ability (somewhat) make them zero maintenance, and perfect for seasonal equipment.
/ 51R Battery for JD4100 #3
How many years do your Optimal yellow top batteries last? I installed a new 51R battery in my Kubota L4200 back in November of 2010 (just checked my records to be sure) and it is still going strong. Purchased it at Walmart for about $100 +/-.
/ 51R Battery for JD4100 #4
we have an account that used the optima batteries for years on a electric lift gate on their trucks cost to be over 200.00 each we changed them over to the gel cell battery and no problems have done about 8 this year for them we only use deka/east penn batteries the gel cell runs about 125.00 each
My first yellow top lasted 8y. The current one 4. I found it dead as all dead a couple days ago. Will not take a charge.
/ 51R Battery for JD4100 #6
Optima was a good battery before they moved their production to Mexico. Since then they are junk, lots of early failures!
any suggestions?
/ 51R Battery for JD4100 #8
Walmart's Everstart Maxx batteries have been getting good reviews and the Exide's that TSC sells have worked well for me.
Lucky for me, both are a few blocks apart. Thank you.
/ 51R Battery for JD4100 #11
I'm two years in to an Optima D51 YellowTop battery on my NH TC33D tractor, and it's still going strong. I do put it on a BatteryMinder maintainer/desulphater when the Tractor is not used for extended periods. (I switched to this when 3 OEM batteries ended up only giving me 3 years of life each, despite regular use of the battery maintainer. In addition to failing after 3 years, each also had serious corrosion issues. The charging voltage checked out. I think it was the vibration that got to them.)
I'm glad I got it when I did. I purchased it for $160 on Amazon in April 2016. The same battery now lists for $240. Does anyone know what is driving this huge jump in price? Are other brands of AGM batteries seeing the same jump?
/ 51R Battery for JD4100 #12
I had a regular Delco automotive lead acid battery last 15 years in the International industrial TLB 3444. I had it on a trickle charger also.
Walmart Everstart lasted 4y. $80 with prorate to get another.
/ 51R Battery for JD4100 #14
I came across this old post and have to follow up...
Both of the Optima Yellow Top batteries catastrophically failed on my mowers after 3 years. Right in the middle of turning the engine over, they just failed.
/ 51R Battery for JD4100 #15
Our Old round Optima Batteries that were so good for so long seemto no longer be reliable quality. The Optima company also would not stand behind their warranty. That fact surprised me.
Anyway, in the last year we replaced the Optima Yellow Top battery pair - 2 of group 31 type - in our backhoe. And the other one in our camper.... and the Blue Top in the boat. Plus red tops in our cars.
Most of the big heavy duty ones got replaced with similar group size Odyssey batteries bought online from the Odyssey factory.
The automotive ones are replaced with Interstate brand batteries - a local commercial type sold in most auto parts houses.
rScotty
UNUSED KJ 20' BI PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20' BI...
2020 Kubota RTV X1140 (A61166)
2020 Kubota RTV...
2005 INGERSOLL-RAND WL-350 WHEEL LOADER (A62129)
2005...
2018 VOLVO VNL64T860 6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2018 VOLVO...
2008 Chevrolet C4500 4x4 Altec AT200A 30ft. Bucket Truck (A61568)
2008 Chevrolet...
(APPROX. 60) UNUSED MISC SIZE RATCHET STRAPS (A62130)
(APPROX. 60)...
