New tires on old trailer
/ New tires on old trailer #1
ThirdMan
Gold Member
Saint Charles, MO
LS MT125
We just bought a used two horse strait in (title says 1974) with two axles. This is my first trailer, but my wife has hauled horses in the past. The previous owner has replaced the floor, lights, sanded and painted it. They got a third horse and needed to upgrade. The tires need to be replaced as the sidewalls are showing cracking and the spare is blown out. The current tires are P215/75R15. Reading around I should be putting ST tires on it, but I am not sure which size (as 215/75R15 is not a a standard size in ST). Should I be putting on ST225/75R/15? I was thinking of just heading over to a tire place or Walmart and buying a set at $50 a tire for them to put on.
/ New tires on old trailer #2
I seem to read about many people on TBN replacing ST tires with LT.
Bruce
/ New tires on old trailer #3
Bruce
I'm not sure what options there are in 15" Lt with a decent load rating. I ran into this on my toyhauler and wound up getting load range E trailer tires for about $100 each.
/ New tires on old trailer #4
If you have the clearance the 225 will work, otherwise you can go down to a 205. I really like the Gladiator QR25 tires, just put a set on my equipment trailer and have another set on my dump trailer. Really impressed with them, especially for the money. I got mine off ebay.
They have the st225/75r15 in C through E range.
/ New tires on old trailer #5
Regardless of which you buy look at the load rating on the side of the tire. Add up the weight of your trailor, horses, saddles gear, water, and other cargo and then buy a heavier duty tire. Tire issues hauling some boxes or boards is one thing. Tire issues loaded with horses is a major issue.
Load range E is about all I buy anymore. Less side wall issues and resulting trailor ride issues.
With 7 trailors, livestock, goosenecks, utility, box, and a little but heavy welding trailor I have learned its cheaper and safer to buy a higher load rating tire. Horse trailors are subject to hot weather and pavement, gravel roads, trail access paths, pastures and other conditions that many trailors never see.
/ New tires on old trailer #6
With more than one axle light truck tires don’t have the sidewall strength to allow turning with a full load.
My life has been changed since I learned why there are tires specifically for trailers.
Growing up I understood that trailers are where old truck tires get a new life and go to die. Still trying to convince my father otherwise.
/ New tires on old trailer #7
I'd definitely go with an ST tire, as mentioned, LT tires are too stiff in the sidewalls to allow for a tight turn. There's been a lot of good reviews in the Goodyear Endurance with a 2830 load rating.
That's the tire I plan on putting on my 5th wheel camper next year
Thanks for the suggestions about ST tires. Looking at load ratings 4 tires on a small two horse will easily be sufficient at D or E. Thank you for the brand suggestions, those are in the price I was budgeting for.
/ New tires on old trailer #10
Lol. Pretty much the same here.
/ New tires on old trailer #11
Too funny! Growing up we had 2 flatbed hay wagons that gave 2nd life to old truck and car tires ... We also had a small single axle box trailer that only went behind one of the tractors into the woods to collect firewood. Since it was never on the road and never saw speeds exceeding 5 or 6 mph it was also a use for 'recycled' road use tires. Years later when I told my Dad that I needed to replace the tires on my utility trailer that I hauled firewood home with (on the highway) he said, "Don't you have anything lying around that would fit?"
Frank
/ New tires on old trailer #12
I am assuming that you have springs, not torsion axles. Be sure to grease all of the pins on the springs. Grease dries up and hardens. Also regrease your bearings, maybe replace them. I had a bad bearing on my first bumper trailer. The spindle heated up and I watched the tire spin off into the bushes - leaving me a nice hot stub of steel on the axle. I switched my horse to the better side and drove home the remaining mile.
When I sold the trailer, the new owner bought a shiny chromed ball from a discount store. His first time out the ball split and he lost the trailer in the ditch, along with another spindle! (Came to ask for the old good one I had hung onto to have it re-welded on to his axle. I had replaced my entire axle.)
Things look shiny with new paint - but rust gets underneath! But steel can be reinforced and welded.
/ New tires on old trailer #13
Just get the same P215/75R15 it has on it now and you'll be fine. That is what is on my old 1976 two horse Circle J trailer and I've never had a problem with many thousands of miles on it.
How did we ever survive before ST tires were invented?:confused2:
/ New tires on old trailer #14
Actually you got that backwards. ST痴 have a much stiffer sidewall than LT痴 because they are subject to substantial side load when turning. LT痴 are made to roll pretty much straight ahead and ride better.
/ New tires on old trailer #16
Good luck finding any ST tires that won't shed the tread after a year or two.
The defective Chinese tire fiasco from 2005 through 2008 when "China bombs" were the norm. Those days are long gone and hopefully, so are the tires that were sent here.
